I cannot print anything off the computer.
This often happens with refilled ink (or toner) cartridges. Inside the cartridges are certain electronics that are designed to last only a certain amount of time. Refilled cartridges do not replace these electronics most often, so after they have been recycled a time or two, they go bad and you end up having paid for a cartridge that will not communicate with the printer. This ends up with the printer telling you that the cartridge is empty, incompatible, or some other warning that disallows you from printing. The best option is to contact the company from which you bought the cartridge and have it replaced.
On another note, be aware that original cartridges for inkjet printers are highly recommended for use because the ink within them not only is ink but also has a bit of lubrication within it that keeps the spray nozzles free of dried ink and, therefore, keeps your print quality at its best. If you wish to save money on cartridges, then most professionals recommend alternating between original and refilled cartridges.
In the world of laser printers, good quality refilled cartridges are just fine to use on a constant basis a toner is nothing more than plastic powder that gets heated by the fusing assembly and melted onto the paper. There is nothing to lubricate parts within it. The only issue is to make sure that you get your cartridges from a company that provides quality units. Lesser cartridges can leak toner that can make a mess inside the printer and/or on your print jobs and can damage the printer. However, unlike popular belief, using refilled toner cartridges will not void your warranty. Rather if any damage is caused by said refilled cartridge, it will not be covered by the warranty but the warranty will remain in effect for anything that is so covered.
I have found that a site called CompAndSave.com (
Ink Cartridges Printer Ink Toner Cartridges HP Ink CompAndSave ) has very good toner cartridges, so I recommend them. I've not had the opportunity to try their inkjet cartridges as I have only laser printers and sell only toner cartridges to my clients but I would think that their quality would be just as high.
I hope all this helps. Let me know if I can assist you further.
