Question about Integra Dtr-7.1 Av Receiver Surround Sound Home Digital Theater Receiver Remote
Integra 7.1 goes into protect mode when turned on aprox. 10 seconds.Any help would be great in getting to work.
Dennis McCollum
  • 137 Answers
You will have defective output transistors
Posted on Feb 19, 2015
1 Related Answer
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Integra DTM 3.5 AV receiver. The
Do more triage first.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Posted on Jun 11, 2011
I have a DTR 7.1 Integra receiver and it goes into protect mode when turned on. Is this something that can be fixed by myself or does it need to go to repair shop.
If you have a volt meter you may try and repair it yourself. First however disconnect the speakers and see if the set still goes into protect. If so you may have shorted output and drive transistors. There will be open resistors near them as well. You can compare the bad channel with a nearby working channel since normally only channel shorts out at a time. Always replace outputs in pairs since they in push pull configuration .
Oct 02, 2014 | Integra Dtr-7.1 Av Receiver Surround Sound...
Sony receiver STR D635 goes to ''protect''mode
Does the set work for the 10 secs. If not you have the protection due to a voltage/current drain in the circuit.The protect works to prevent any further damage to the amp and is a safety feature. To look into the fault it is important to have an idea to go about. Disconnect the speakers and check if the fault changes, if so check your speakers for short and replace them or the coils. If not the output of the amplifer can be faulty. check in the output stages with a multimeter for failure of any biasing resisitors that can also drain more current. If you are not familiar get help. The failed component can be replaced after disconnection and testing. Hope my advice helps. Good day
Jul 23, 2010 | Sony Audio Players & Recorders
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK [email protected]
Aug 28, 2008 | Sony STR-DE445 Receiver
DCR TRV 22 sony camcorder
coonectors going to the main board board get loose. two the top and one going to the lens. also the back side of the top connectors have to have a protective film strip applied across the back of them .
Sep 16, 2007 | Video Cameras
Unit goes into protect mode
Not unless you know how to troubleshoot solid state electronics. If you disconnected the speakers and the unit still goes into the protect mode, most likely you have a short in one of the power output stages. Good Luck
Jun 03, 2007 | Marantz SR-4200 Receiver
Integra Dtr-7.1 Av Receiver Surround Sound Home Digital Theater Receiver Remote Logo
266 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
