I have a Pioneer HTP-2920 sound system and am trying to hook it up to a Vizio TV and am having problems. I also am having problems with trying to use it for sound with my PS3. The cable that I have is Directv. Any suggestions?
SOURCE: Pioneer htp 2950 home theater system
There is a problem with the volume controller chip, or a problem in the paoer supply feeding the main amp. Good Luck
SOURCE: Pioneer HTP-100-SW
i just installed my htp 100 sw. the scheme was atached to the back of the woofer for me tho. easy. front speakers go into the sub in the two botom inputs from the receiver. the two upper are outputs to the actual speakers. hope it helps
SOURCE: I can't get my tivo to change channels. It stays on the same channel
I believe that you are already on the right path, your tivo will still be assuming that you are running off the cable box plus you watch dancing with the stars for five minutes one time just to see Warren Sapp attempt to dance and now all of a sudden it wants to record every single piece of televison with dance in the title or discription, but I'm not bitter.
Just re-accomplish the set up and let it know that you are no longer running a cable box. Also tell it that ditching you friday night to hang with it's old high school buddies was so not cool.
SOURCE: hook up vizio tv to fios box
Run HDMI from FIOS to TV directly, then run Digital coaxial or optical to the cbl/sat audio input of your receiver. That's it. If you have any more questions, just post a comment and I can help more.
SOURCE: how do i connect my Pioneer DV-250 to my Vizio 32
hi there, is you tv black box hd? if this is hi-def you should have red/blue/green cable in/out to & from tv to box....dvd is out jacks to tv digital in..in order to watch the dvd using remote tune to source tv/av1/av2/cable more
feel free to rate the help
