For most Microlife blood pressure monitors, the error 3 indicates that the unit cannot reach the proper pressure in the cuff to start the test. If replacing the batteries doesn't work, check that the cuff is properly plugged into the socket on the monitor. Next you may need to replace the cuff. There may be a leak in the cuff or the hose between the cuff and the socket. Microlife sells replacement blood pressure cuffs here: https://www.microlife.com/consumer-products/blood-pressure/cuffs-and-supplies . These cuffs fit all of their devices except for the wrist versions.
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
blood pressure monitor replacement cuff, links below are to replacement cuffs and are fairly self explanatory to install press the helpful button and follow me on fixya for more tips
Are you moving your arm at all after you press the start button. I just have a wrist cuff, but if I move anything after I've pushed the start button I get an error code.
Hi Brenda....if I knew the maker of the product I would give you
a number for Customer Service. If you have the purchase
receipt by all means take it back and ask for a refund. Good
luck.
According to the Owners Manual, the EE Message shown on the display or the blood pressure value is displayed when an excessively low (or high) reading is detected OR as a result of one of the following:
1. Cuff has been placed incorrectly. Solution: Wrap cuff properly so that it's positioned correct.
2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady at heart level during measurement.
3. Shaking or moving of the wrist with the cuff on. Solution: Same as # 2.
NOTE: Be sure the cuff is placed exactly as pictured on the face of the box, 1/2" above the heel of the hand.
hi, the part of the arm the cuff goes round is the upper part it goes over the muscle at the top of the arm, if you start at the shoulder and go about to hands witdths down the arm this is where the cuff goes around, hope this is some help to you, if your unsure give me a shout back
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff An adequate pressure cannot be generated in the cuff. A leak may have occurred. Replace the batteries if necessary. Repeat the measurement.
Err 0 No pulse is detected Err 1 Inflation rate is too low Err 2 Systolic reading unattainable Err 3 Cuff pressure is too high Err 4 Diastolic pressure is outside of operation range Err 5 Cuff deflated too fast Err 6 Cuff deflated too slow Err 7 Systolic pressure is outside of operation range Err 8 Overall pressure is outside of operation range Err 9 Cuff is unable to inflate to the necessary pressure level -------------------------------------- Error No. Possible cause(s) Err 1 No pulse has been detected. Cuff may be positioned incorrectly. Err 2 The arm was moved during the measurement. Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
monitor not measuring BP. Cuff inflates but does not give a reading
