I have a hmdx rave and a next book. I looked on my settings and there is no Bluetooth.
Yes, you'll need a 3.5 mm audio cable (PC audio) with M/M ends. Connect the cable between the headphone jack of the Next Book and the Aux Input of the Rave speaker. The Aux Input jack on the speaker is between the charging port and the On/Off switch. The headphone jack is between the power button and the DC Power Input port on some Next Book models; you should check your unit's documentation for the exact location. Only the volume controls on the Rave speaker will work. You'll need to select tracks and press Play/Pause on the Next Book.
I hope this helps.
You must turn on the tablet's Bluetooth radio before you can enjoy using any Bluetoothy peripherals. Here's how to activate Bluetooth on an Android tablet:
Open the Settings app.
On some Samsung tablets, touch the Connections tab.
Ensure that the master control next to the Bluetooth item is set to On.
Slide the icon to the right to activate.
When Bluetooth is on, the Bluetooth status icon appears. It uses the Bluetooth logo.
You'll also find a Bluetooth switch in the tablet's Quick Actions.
