Question about Brand Remote Start/keyless/car Alarm Very Sleek
How do a reset the factory fitted alarm and central locking on a 2003 golf 1.4i
How to connect aftermarket alarm with factory central locking Hyundai i20
What's the year, make and model of the vehicle? What alarm did you use, brand and model?
Feb 22, 2014 | Vehicle Parts & Accessories
Mazda 2 (2004) central locking and alarm fault. My
how can i find central locking in mazda premacy tell me plsss
Oct 01, 2013 | Mazda Cars & Trucks
My 2007 golf immobiliser will not deactivate the alarm with the key fob, i have re coded it still nothing, removed the fuse and its fine. central locking also doesnt work. all factory fitted stuff.
its a 2007 model and as such can have the key fob reset with dealer diagnostic software ,wouldnt have thought removing a fuse would de-actrivate the factory immobilisor though
Apr 09, 2011 | Volkswagen Golf Cars & Trucks
I installed a new battery on my 95 vw golf, however when I connect the terminals the alarm sounds on the car. How do I install it without the alarm sounding?
just connect the terminals,and wait till the alarm stops(30secs)then UNLOCK/HOLD KEY OVER 30 secs,windows go down.then lock/hold key over,windows go up.then press remote unlock button for 30 secs,you have just reset the alarm system/central locking/window comfort facility.....has to be done EVERY time you disconnect battery........
Nov 08, 2010 | 1995 Volkswagen Golf
I need central locking fitted to my golf
Besides the cost of the part, they have a flat rate charge per hour. So to have an idea, ask how much time is allotted for this job that VW recognizes it should take to fix it then you multiply the time to the flat rate.
Apr 19, 2010 | 2003 Volkswagen Passat
My central locking on my 1997 vw golf just stopped working it sounded like it was trying to work but now does nothing. also the gas tank cover wont open as its stuck on lock...any advice on what i can try?
the gas flap is operated with the central locking,stand at rear of car with tailgate open,just inside to the right,under the floormat you will find the central locking pump.but first renew the batteries in the remotes then unlock the car with the key and hold the key over for 30 secs, the windows may go down,
then lock the car with the key and hold over for 30 secs,the windows may go up and the sunroof,if fitted will close,then unlock with remote button held down for 30 secs,this will reset alarm/central locking.
if you need to get to gas flap, pull carpet away in boot behind flap area and pull wire to unlock....
Mar 19, 2010 | 1997 Volkswagen Golf
VW Golf security/central locking overridden by another fob.
is a cheap alarm. change it wih a proper one.
both of you have alarms which is working on the same freqvency. the same alarm, or just weird coincidence.
Feb 27, 2010 | 2003 Volkswagen Golf
VW GOLF CENTRAL LOCKING FITTING
do you know the trick how to get your key to work with any door barrel or are you just focusing on central locking?
May 18, 2009 | 1996 Volkswagen Golf
1999 golf, alarm rings when open with key fob cant turn off
the alarm itself could have an internal earth problem.... pull out fuse from alarm or disconnect alarm and see if fuse still blows
Mar 21, 2009 | 2000 Volkswagen Golf
Brand Remote Start/keyless/car Alarm Very Sleek Logo
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Kardoc
Mr.Mike
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
