What can i do with error code f2-02?
The cartridge contains toner powder but it shows the code f2-02.
Eric Andersen
    Habit-Forming:
    New Friend:
  • 72 Answers
Http://www.copytechnet.com/forums/sharp/91581-ar-m620n-f2-02-error-code.html
Posted on Sep 29, 2014
5 Related Answers
ROD GANDY
  • 1602 Answers
SOURCE: Message: Dispose of use toner powder
try installing a new cartridge or a reconditioned one it would be cheaper, some have exchange of toner catridges and a small fee for a reconditioned one
rod
Posted on Feb 03, 2009
Anonymous
SOURCE: replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Posted on Aug 26, 2009
Anonymous
SOURCE: black is printing very lightly - brand new black
The problem you are facing with this machine is the hopper is clogged where the toner falls into the machine. You need to go into the maintenance section of the printer and clean the black developer. The cycle of cleanings will bring the toner down so that it prints black again.
Square Imaging, Inc.
www.yourlink4ink.com
Posted on Sep 18, 2009
Anonymous
  • 27 Answers
SOURCE: How to refill toner cartridges HP Q6000 black? (printer HP 2600n)
no holes are need it
check this video it is very easy with no special equipment
http://www.youtube.com/watch?v=iMiTopIVMxM
Posted on Sep 30, 2010
clrvuedoc
clrvuedoc
  • 175 Answers
SOURCE: MFC 8460N said: the toner cartridge life end even
  1. open cartridge cover
  2. press clear/back
  3. "replace drum?" pres 1 for yes
  4. wait for accepted and then shut the front cover
  5. press stop/exit button
Source
Posted on Mar 04, 2011
Testimonial: "thank you very much! the problem has been solved succesfully!"
The cartridge contains toner powder. Why is it displaying code f2-02?
did you refill it. if the cartridge has a electronic chip on it then you can refill it all day as long as the chips say i am dead then when it goes into the machine the machine reads the chip I AM DEAD buy a OEM cartridge and replace
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 11, 2015 | Sharp Office Equipment & Supplies
I changed the cartridge in my oce fx3000 copier and I still get the message "change drum" and it won't work
The toner cartridge is a completely different unit from the drum unit. The drum unit is replaced separately, and is good for about 25,000 pages. The toner cartridge contains the toner powder. The drum actually fuses the toner powder to the paper.
Feb 26, 2015 | Office Equipment & Supplies
Will it fit hp officejet 6500a
No the 92A cartridge will not an OfficeJet.
LaserJet printers take toner which is like a powder, both the toner and the paper are given an electrical charge so the toner will stick to the paper. In the OfficeJet printers the cartridges contain ink which is then sprayed onto the paper much like a spray paint.
The OfficeJet will take No 920XL cartridges.
Mar 17, 2013 | HP C4092A Laserjet 92A Black Print...
I want to know what is inside the printer cartridge
The ink cartridge are of different type and contains ink in different form.
  • Thermal Ink jet Cartridge (HP, Canon) - The cartridge contains a liquid ink, which is heated by a heating plate on the cartridge. A bubble is formed which forces the ink which comes out of the nozzle.
  • Piezoelectric Cartridge (Epson) - The cartridge contains piezoelectric crystal, which when current is applied changes shape and size forcing ink out from the nozzle.
  • Toner (Laser Jet Printer) - A drum contains powdered ink (toner), which is spreads on the paper using negative and positive charges and the heater sticks the ink on the paper.
Regards,
Shrey
Jun 07, 2011 | Computers & Internet
Can i refill tonner on MFC- 9440 CN laser printer
You can, but it a dirty job. I would not recommend it as the toner powder is very fine and you don't want to breath in this toner powder.
If you don't want to purchase a new toner cartridge, then I recommend you buy a re-manufactured toner cartridge for your model printer. They cheaper than the new Brother toner cartridges and usually contain more toner and the drum cartridge components have been refurbished.
Feb 24, 2011 | Brother MFC-9440CN Laser Printer
How can I refil Toner my laser printer
I would not recommend refilling your toner cartridge, the toner powder is very fine and you do not want to breath in this toner powder.
I suggest you purchase a new toner cartridge OR a re-manufactured toner cartridge for your model printer. Re-manufactured toner cartridges are much cheaper than new toner cartridges.
Dec 15, 2010 | Office Equipment & Supplies
I have a LBP 2900 B Canon printer. pl. give me a idea of this tonner refilling. step by step procss of refillng tonner, show in details drawing.
I recommend you do not try refilling toner cartridges, the toner powder is very fine and you do not want to breath in this toner powder.
You can purchase a new toner cartridge or a cheaper alternative is a re-manufactured toner cartridge.
Dec 09, 2010 | Canon LASER SHOT LBP-2900 Printer
How to refill ink in it
The printer doesn't use ink, it uses toner, a black powder. The toner is then pushed onto the page using magnetic force and fused to the paper using a laser. Which replaces the traditional "ink injection" method.
The toner cartridge is a black unit that pulls out located behind the top access panel in the front. This unit contains a glass drum and behind it a well of toner powder. Usually you have to replace the entire unit.
There are toner cartridges with plastic caps which can be removed and then refilled with the powder. However, this powder is messy, difficult to manage, and eventually the drum will become scratched and worn since it is not really designed for prolonged use. So I recommend just replacing it.
While the toner cartridge will run more than ink. The frequency with which you have to replace it is significantly less. So while ink can run you as much as $0.25 a page when you factor in the wear and tear on the printer. Laser printers are more along the lines of $0.04 a page.
If you replace the toner, read the directions carefully and be sure to remove the plastic shipping strip from the side of the cartridge. This strip is used to hold the toner in the cartridge while it ships and will keep it from working properly.
May 12, 2010 | Canon LASER SHOT LBP-2900 Printer
What is the difference between a toner and a drum on a BB4400 OKI printer?
The toner is the black powder which the printer uses to turn type and pictures into a printed piece. The drum is the device that actually fuses the image to the paper. Toner cartridges and drums have a service life. Toner cartridges will have say a 3000 sheet capacity. When it is empty you replace it. The drum will have a 10-20,000 sheet capacity. Typically the drum is three to four times more expensive to replace. Many companies will give you a credit for turning them in vs ending up in a landfill.
Good luck.
Aug 04, 2009 | Office Equipment & Supplies
Oki 3400n
First thing to do (if not yet done so) is to access the printer through the web admin interface by typing the printer's IP address in a browser. This gives a lot more information than the blinking lights.
The Status page of the web admin interface may say "toner low" or "toner empty" or "error on toner sensor" and that will tell us which color cartridge to handle.
Note that the OKI 3400n has the annoying tendency to fail when loading in a new toner cartridge: a color is low or empty, you put in a new color tube and then the printer says error on that very color! This can be fixed by pulling out the drum of that color (the drum is that entire block which includes the color tube and the container below it; avoid touching the shiny green roller), and lightly tapping on that drum to evenly distribute the new powder inside the container.
You may have noticed that the once the color tube is loaded in, what it does is to empty its content into the container below. Which means that it's no use swapping color tube once it's installed because the color tube is empty by then, and is just kept there to prevent the ink powder from spilling out of the container. The caontainer itself has 5 electrical contacts on its side used to measure the powder content and the lifetime of the drum.
Viet
Aug 29, 2008 | Office Equipment & Supplies
559 people viewed this question
Ekse
Marvin
Marvin
