Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
SOURCE: Sharp lcd flat panel won't power up.
You will most likely need to replace the power supply. This is a very common problem now days, especially with newer electronics.
