Question about Voyetra Turtle Beach Ear Force X3 Wireless Headphones for Xbox 360
The sound comes and goes from right part of headset
I have been having this problem for about...2 weeks and never found out what it is. The sound in the left earphone works perfect, but the right ear phone works, then fades out, then goes back and forth. My wire connecting to the headset to the controller starded fizzing and then all of a sudden, my mic broke. I really need help fast so plz tell me anything that might work, thx!!!
  • 32 Answers
The left/right problem could be a bad connection on the red/white XBOX cables. Check to see that they're plugged in properly and not loose. You can also try plugging an MP3 player into the red/white jacks to see if the problem is with the headset or the XBOX. If it works ok with your MP3 player, then the headset is working fine.
You can get a new headset controller cable on our web site. Click on Replacement Parts in the left menu for the headset model you own (X1, X3, or X4).
Posted on Jul 17, 2009
6ya staff
SOURCE:
Why am i getting no power in x42 turtle beach earphone?
I am assuming this is not a sound issue, and an entire headset not coming on issue. Here are the steps that I would take...
1. Put in BRAND NEW BATTERIES!!! (Usually that is the culprit) ;-)
2. Unplug and then re-plug in all wires and cords to the console and the controller.
3. Check to see if the wires are connected from headset to end cords (on the one that plugs into the controller).
4. Once everything is connected and with brand new batteries, it should work, turn it on again. Remember the beep sound goes up when the turtle beaches come on, and the beep sound goes down when the turtle beaches are turned off.
Jul 02, 2014 | Turtle Beach Ear Force X42 Headset
I plugged in my usb-comected headset. Now the sound-output comes only through the headset. The speakers are disabled. When a switch the output to the speakers (comfiguration) ik cam use the headset for...
Unplug the headset. I found in computers the computer knows when you plug it in and when you remove it. I do this a lot with a USB sound card. It's like plugging into the sound card and pulling the plug out, but with USB connection instead.
Nov 13, 2017 | Logitech H530 Headset
I am having trouble pairing the Jabra Stone with my iPhone 3gs. I have held down the stone button multiple times and nothing happens. Also i have turned it on and off multiple times, but it just wont...
Hi, Look for "Add new device". Hit OK.
the phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
I've reviewed Bluetooth headsets before, and I would have to say that the Jabra STONE is one of the sleekest looking. Its shape is designed with minimalist simplicity, with a shape made for either the left or the right ear.
This shape goes onto a charger that is perfectly made to accept the Jabra STONE like a puzzle piece. This charger is probably what sets the STONE apart from most Bluetooth headsets, as it can charge the headset as the user goes. A green indicator means that it has enough charge for one full time or more. The red indicator means that it needs to be charged.
The STONE can be charged with an AC cord or USB connection. Once it is charged, there is a pairing indicator that made it simple to sync with my mobile phone. It has about 12 days (288 hours) of standby time and 8 hours of talk time.
I found that pairing the STONE with my phone was quite simple. In a matter of seconds, it was connected to my phone and I was making my first phone call on it.
The sound for the STONE is pretty good, with dual microphones and their trademarked Noise Blackout Extreme and crystal clear sound and voice with DSP.
One of the big features that I found is the touch sensitive volume control. In other words, there is no buttons for controlling the volume. I welcomed that, and most volume controls on Bluetooth headsets are really, really tiny buttons.
Other features include the ability to connect to two devices at a time, and it can stream music from an A2DP enabled mobile phone.
This is the problem that I had with the STONE. I found that there isn't really a "standby" indicator. I found that using it was a hit or miss situation. If I just pulled it out of the charger, it would sync with mobile it would work. When my phone rang later, and the headset was out of the stone cradle, and hitting the "connect" button didn't help. In short, I had to answer my phone. The Jabra STONE failed me, but I remember having similar awkward experiences when I first used other Bluetooth headsets.
The Jabra STONE comes with the headset, charger, 2 Eargels, a belt clip, AC charger, and a USB charger. You should be able to get it on Amazon for about $90 as the price to this writing.
Feb 24, 2011 | Jabra Stone Bluetooth Headset
I have a problem, i had this headset for 2 months and now I can only hear things on the RIGHT side and i dont know how to fix it. I was only using it regularly and then one day all the sound just comes...
Dear angelqueenof,
May I ask you to use a spare headphones connected to the same source audio plug to verify if the issue comes from the source or from the Logitech ClearChat headset.
Regards,
Eddie Knight
Dec 28, 2010 | Logitech ClearChat Pro USB Headset
I need to get sound incoming with headset how do i do this?
Specifying if this was Windows XP or Windows Vista would make a difference in the fixing of this problem, I am going to explain for Windows Vista hoping that you are up-to-date on the most recent operating system.
Step 1: Locate your task pane in the bottom right corner of the screen.
Step 2: Playback options (I believe)
Step 3: Under "Playback" select your headphones from the list.
Step 4: Right click it and click "Set as default device"
Wallah, it should send the sound to your headphones now rather than the PC's output device, please note, once your not using the headphones anymore you must set the default device back to the normal speakers or you will have no spound.
Apr 27, 2009 | Insignia Bluetooth Wireless...
925 Plantronics will not pair with cell phone.
You are holding down the main button too long.  When it flashes blue and red it is now in pairing mode.  To turn on the headset hold down the main button until you see the blue light come on, then let go.  If you hold it any longer this is when it goes into pairing mode.
Feb 24, 2009 | Plantronics Discovery 925 Bluetooth...
The Headsets wont power on.
Go to the logitech website (google found the following)
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
You might try the troubleshooting link first but on the Right Upper side of the page is a Phone contact link which goes to here.
http://www.logitech.com/index.cfm/447/3876&cl=us,en
These numbers are valid.
Not sure why you couldn't find it, site seems to be easy to navigate. Maybe it was down at the time. Please post again if there is more needed to help.
Apr 03, 2008 | Logitech FreePulse Wireless Consumer...
No sound comes from my headset
had same problem i found just turning my phone on and off to solve the problem
hope it helps
Mar 03, 2008 | Motorola Mobility H500 Wireless Headset
Battery
A fully charged battery should last up to 4 hours if it's being used A LOT! But I lost mine and it was in standby mode for pretty close to 3 days and when I found it I was still able to use for quite awhile before charging it again.. So yes, it sounds like it had a weak battery..
Oct 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Connecting phone to bluetooth
had the same problem but this site reminded me to hold the phone button down 7-8 seconds. I was simply not waiting long enough - took more like 12 seconds.
Apr 05, 2007 | Jabra BT250 Consumer Headset
Voyetra Turtle Beach Ear Force X3 Wireless Headphones for Xbox 360 Logo
563 people viewed this question
Top Voyetra Turtle Beach Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Voyetra Turtle Beach Audio Player and Recorder Expert? Answer questions, earn points and help others
