Question about Motorola Mobility S11-HD Bluetooth Headphones
What sound adjustments can i make with my headphones
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Motorola Mob... Master
  • 1,001 Answers
  • Advanced Technology,The Buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music .
  • Protect the earbuds when you during runing and workuots have sweat.Compatible with iPhone 6/6s,6 Plus/6s plus, 5 5c 5s 4s,iPad Air, Samsung Galaxy S6,S5,S4,S3 Note 4 3, HTC M9 M8 M7, LG Flex 2 G3 G2, and Other Bluetooth Android IOS Smart Cell phones/Devices
Amazon com Bluetooth Headphone Charm sonic Wireless Headphone for Gym...
Posted on Dec 20, 2016
Motorola Mobility
  • Official Brand Answer
  • 1,623 Answers
My levono C460 system sound is off so no sound what can i do?
Hi
3 possible solutions:-
• Adjust the Windows volume control - select the speaker icon from the Settings Charm or click the arrow on taskbar to show the hidden icons in Windows desktop mode, then click the speaker icon. Ensure that the volume is turned up and the sound is not muted. Adjust the volume, bass, or treble controls to eliminate distortion.
• Reinstall the audio driver.
• Disconnect any headphones from the headphone connector - sound from the speakers is automatically disabled when headphones are connected to the computer's side-panel headphone connector.
I also give a link below to a page from which you can download the full manual for future reference.
Desktops and all in ones Lenovo Series all in ones Lenovo C460 All in One...
Cheers
Oct 26, 2014 | Computers & Internet
How do i get sound through headphones?
Check in the tv's menu, theres usualy a separate volume adjustment for headphones
Jul 28, 2014 | Bush Televison & Video
Headphone jack not working on dell d810
andys_cars,
You may need to go into the sound properties and then to deviceto change the settings to enable the speakers and change it from headphones to speakers.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 04, 2013 | Dell Latitude D810 PC Notebook
My headset is not working
Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Jan 16, 2013 | Computers & Internet
Dell laptop headphone sound on out headphone no sound
Sound Loss in Dell Computer Headphones b> Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
b>
Dec 29, 2012 | Hitachi VisionDesk 1330 (1330-001) PC...
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | RCA Audio Players & Recorders
No sound in headphones
plug in head phones
Go to control panel
go to multifunction sound machine or similiar audio adjuster
if there is an auto detecter click yes ok etc. to turn it on
if not then click headphones under speaker adjustments apply then ok
try then if not try a different pair of head phones some arent pc compatible
or jack could have probs hope this helps
Mar 18, 2010 | Acer Aspire 5720 Notebook
No sound coming out of the left speaker
It sounds like you have a break in your cord right where it joins the plug. You will either have to replace the plug or buy new headphones.
May 18, 2009 | Audio Players & Recorders
Sound problems
This is a common problem with mp3 players - the headphone jacks are sensitive; it's not worth replacing, because the next one is going to do exactly the same thing. The only thinkg you can do is make sure the headphone stub is parallel to the top of the mp3 player and be real still.
Jul 01, 2008 | RCA OPAL M4001 MP3 Player
Microphone is not working
1-adjust the overall volume by pressing fn+f 5 hotkeys
2-adjust sliding mixer controls by doubleclicking the speaker icon
3-disconnect the headphone jack to enable check of internel speaker.4-confirm that microphone plug is proper connected to mono mic jack.5-confirm that microphone is selected as recording source in control panel----multimedia and recording level is adjusted.
confirm that sound source is selected in control panel----multimedia
confirm that headphone connector connected in right postion
Jan 24, 2008 | Compaq PC Microphone (Black or Beige)...
Motorola Mobility S11-HD Bluetooth Headphones Logo
139 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
john h
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
