Question about Pride Jazzy Select Elite
New batteries placed in. power light (red)and green light both come on green when plugged into charger but joy stick shows that battery not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Posted on Nov 06, 2014
SOURCE: Hi. Our pride Ranger PMV
Hello Simon.Visit-www.alldatasheet.com its free.Download as a PDF File & save + if you choose print for future ref.To your Adobe Reader.Type in the correct boxes for a troubleshooter.Merry Xmas,any problem,please ask again,Colin.
Posted on Dec 16, 2010
SOURCE: Pride Sundancer. Batteries will not charge. both
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Posted on Jan 17, 2011
SOURCE: battery charger indicating that batteries
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Posted on Mar 15, 2011
SOURCE: battery charger for pride
Is there a power switch on the charger? Is charger connected to the battery? Are the batteries fully charged?
Posted on Aug 20, 2011
make sure you have the batteries installed correctly positive to positive
Posted on Oct 14, 2012
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
on Sep 20, 2010 | Health & Beauty
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
Feb 19, 2011 | Pride New Jazzy 600 Power Wheelchair by...
Nov 07, 2010 | Pride Go Chair Travel Power Chair
Sep 08, 2010 | Invacare Pronto M51 Power Wheelchair
Sep 06, 2010 | NRS Hoveround MPV 5 - Used Power...
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
510 people viewed this question
