Question about Oreck BB2000 XL Little Hero Canister Vacuum
How do i open xlcannister to put new bag in--
ka4iup
  • 4,062 Answers
Http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1426568065661/images/userguides/Canister-LittleHero-BB2000-userguide.pdf
Posted on Mar 17, 2015
Blue plastic bag holder on oreck upright detached - how to put it back in?
Amy, not sure from your description whether the outer part is what came off or the smaller, inner part came off. If it is the outer part, all you need to do is squeeze the two prongs of the inner part of the bag holder together and slip the two pegs into the holes on the outer part of the holder. If the inner part came off then you have to spread it, so that it will go over the opening on the handle, and then follow the directions I gave to install the outer part. Hope this helps.
Feb 17, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Took bag completely off and now I can't put it back together
Put the outer bag back on the unit. Make sure that you have pushed the outer bag down past a black lip. The piece that holds the inner and outer bag on the vacuum needs to be put on next. The small horseshoe shaped plastic piece goes on with hte open part down. Make sure that the docking station goes behind the lip I told you about. Next put the piece that the inner bag slides into on. This should have the bag back on the vacuum and ensure that it is on properly. If not, then it will pull of pretty easy and blow dirt into the outer bag...not the one that is meant to catch the dirt....I am a manager of an Oreck store.
Dec 04, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Bag light on saying, but new bag with nothing in it
There is either a restriction in the hose or else the air filter is dirty causing a pressure differential. Remove hose and inspect or push a broomstick through, also try putting a opened coat hanger through the inlet of the vacuum where the hose connects. If you remove air filter and it goes out, replace air filter.Hope this helps you
Jan 19, 2011 | Sebo X4 Bagged Upright Vacuum
I recently put a new bag in my kirby and now when i turn it on, it will not pick up anything
see if you connected it or install it correctly, see if there is any leackage of air, see if it is air tight, the reason is that the air cannot vacum because there might be some open connection between the bag and the air exhaust of the vacum
Nov 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I cannot figure out how to put the bag in
theres a slot on the front stick your 2 fingers in there and pull ,its right above the front cover,then just pull the old bag out and push in the new bag.please leave feedback
Apr 04, 2009 | Bissell 3522 PowerForce Bagged Upright...
Hi, Fitted new paper bag to this cleaner but have 'No' suction. With bag removed no air movement can be felt at outlet(ie bag entry). Have you any suggestions?. Many thanks, John Pessall.
What kind of model is it?
If you have the bag door open just to feel if there is suction it won't work. The machine would have to have its door put back on before suction can be ascertained. In the meantime check the hose that leads into the bag, or main dust channel - it may well be clogged as well as motor filters usually located under the paper bag.
Mar 02, 2009 | Vacuums
I can not find how to get the canister apart to empty the dirt.
From the bottom of your machine going upwards past the handle that is on the canister portion of this vacuum, you will see that the top of that canister had a depression where you should be able to put your fingers in, and gently pull that lid back, opening the vacuum bag compartment. According to the manual, simply pull that back, exposing the bag. To remove the bag, pull the cardboard plate on the top of the bag, out towards the no open face. Throw away your old bag, and take your new bag, fold down the paper sides of the bag, then slide the new bag into the track completely. Close your lid, and you are done.
While you have this compartment open, it's a good idea to check your filter that sits below the paper bag.
Part numbers
Paper Bag: SC-P11
Filter: SC-F2
I hope this helps you.
Jan 20, 2009 | Sanyo Transmax SC-180 Handheld Vacuum
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vaccum Bag
Slide the plastic piece off the cloth bag and open the top. Looking down into the cloth bag, you will see the old bag. It is secured to the machine near the top. You will find the cardboard collar about a third of the way down. Remove it carefull. Now, stand BEHIND the machine and put your knee against the back of the handle and taking the new bag, open the hole in the cardboard collar and insert the bag into the cloth bag and put the cardboard collar onto the handle fitting. It helps to put the lower part of the hole on first and then press the top of the collar onto the handle fitting. The idea of standing behind with your knee against the handle is so that as you attach the bag, you will be pushing against your knee which will steady the machine and allow you to use the required force to complete the action. Once completed, fold the top of the paper bag down, so that when you replace the top slider, the paper bag is NOT clamped between the cloth bag and the slider.
Jan 25, 2008 | Hoover Soft Light U4266-940 Bagged Upright...
Oreck BB2000 XL Little Hero Canister Vacuum Logo
110 people viewed this question
Top Oreck Vacuums Experts
Muntejaya Ginting
Muntejaya Ginting
john h
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
