Acer Aspire E1-571-6650 Laptop Logo
Question about Acer Aspire E1-571-6650 Laptop
I dont think i have the right battery for my acer aspire q5wph
Battery and power cord info
stephen Adams
  • Acer Master
  • 2,219 Answers
The correct description is Acer Aspire E1 series.
The battery model number is AK.004BT.097
Spec is
  • Cell - 4 Cell
  • Chemistry - LI-ION
  • Capacity - 2500MAH
  • See Datasheet
    Acer Store 4 Cell Li Ion 2500mAh Battery
  • Posted on Feb 08, 2015
    5 Related Answers
    Anonymous
    SOURCE: Acer Aspire 3680
    My daughters laptop was doing the same thing. No power indicator light or battery wasnt charging, but the charger was putting out ok. Found on the laptop were the power adapter plugs in the center
    plug pin was broke off in the plug of the adapter making it look like a new syle special plug, Had to change the female recept. on the back of the computer.
    Posted on Oct 07, 2008
    Anonymous
    • 4 Answers
    SOURCE: Acer Aspire 5100 Red Battery Light
    Make sure your universal charger is EXACTLY the same voltage as the old charger. I had a dell laptop that someone and had a universal charger on it and the cpu would always run in powersaving mode and the battery wouldn't charge so I bought a dell replacement off of ebay and it fixed it. Just a side not, the battery light would flash red non stop.
    Posted on Feb 26, 2009
    Anonymous
    SOURCE: Acer Aspire 7520 turns off and on repeatedly
    Mine does this but what I found was that if you hold the power button down for about 10 seconds when you are turning it on, it works.
    Posted on Apr 02, 2009
    Anonymous
    • 109 Answers
    SOURCE: I have an Acer Aspire one model zg5- Power cord
    Here is another thing you can try. Unplug the power cord, and then remove the battery. Press the "Start" button and hold for 5 seconds. Replace the battery back into the computer and plug in the power cord. Start the machine and see if the low battery message still comes up. Sometimes the program that monitors the battery status gets confused. Doing the above should straighten it out. The Acer should start up and the AC power light should be lit. Look down in your task bar for the battery Icon or go to Battery Status in Control Panel and see if it shows that the battery is charging. Even newer batteries can go bad (rare) but if this is the case and a cell has shorted out in the battery, then your only recourse is exchange under warranty.
    Posted on Jul 18, 2009
    Anonymous
    SOURCE: my acer aspire 5810tz can not be started in
    how old this battary ?
    Posted on Mar 06, 2010
    AO532H dont power up
    I can't help you without more info? Is it plugged in? Have you tried another AC outlet? Have you tried another cord/charger? Remove battery? Has it beed damaged, or spill of liquid? Have you done a OS upgrade? etc, etc, etc.
    1helpful
    My acer aspire 8930 suddenly stopped charging the battery. We put it in my husband's identical laptop and it charged fine. I researched on net and using info found, turned laptop on with battery r
    Just because all systems look go. Does not mean the power cord is working correctly and the charging portion of the power supply unit may not be working you will still be able to power the computer on but not charge replace that unit and you should be back up and charging again. You know it is not a battery problem it is the cord and component due to your test. Makes sense to me also one other factor to consider, the battery may be charging but will not hold the charge be sure to fully charge the battery and see how long it takes to drain down. Just a suggestion. John
    My acer aspire starts up to the microsoft logo then turns off. i think the battery is dead because when i take out the power cord the battery light goes out. but should it still start with the charger...
    Hi
    If your battery is dead you can still use your laptop with the power cord connected and turned on
    have you tried charging your battery for a couple of hours with out using the laptop just to see if the battery will charge and hold its charge for a while
    many thaks
    Hello, ive plugged my charger into my acer aspire one netbook, but no chargin light comes on. when i press the power button it comes up green but the screen does not come on. ive hooked it up to an lcd but...
    try this okay take out battery for five mins then replug the power cord in sometimes the sensor dont recgonize but if that dont work its the battery charger end that coulbe be messed up
    Acer power cord
    if you can use your notebook without the battery with the power cord attached, then the battery ist defective. If your notebook doesn't power on at all without battery, then the power cord is faulty.
    After booted up and just sitting there for a few
    Get the battery checked. Its malfunctioning. you probably might need to buy a new one.
    My acer aspire 5315 laptop will not stay on. I can connect to the internet, surf the web, but then it will just shut off like it has lost all power. Is it my battery or my power cord? Or is it something...
    Hi there , i think its a cause of your RAM. Remove the RAM from motherboard. clean that & also the RAM slot. Then run your system again. Another reason virus. scan your laptop with updated antivirus.
    I am sure at a time your battery & power cable both can't be damaged. If your battery power cable damaged then you can see your system run by battery or opposite right? So try these and follow the battery & power indicator also.
    Thanks & waiting for your feedback.
    2helpful
    2answers
    Power problem
    I don't think you are dealing with a short in your system. Your battery is probably dead and/or needs to be charged. See if your new power cord will work and will turn your computer on. Make sure that you have the exact power cord that your specific system calls for, because not all laptop power cords are the same. I mean you can't just use any laptop power cord; it has to be one that is rightly built specifically for your laptop system.
    Steve Sweetleaf
    Steve Sweetleaf
    shadow
