Repair man replaced a faulty door seal and door catch. Used compatible not hotpoint. Door does not seem as secure as old one. Still leaking underneath at front of machine on full load rinse or spin. No water at back/
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
SOURCE: How do i change the door seal on hotpoint ultima wf860
hi this is a ten minute job take your lid off your machine and then take you soap drawer out there are 2 screws in the behind the soap drawer undo these unclip the top board as you look in side the machine and put the fasia in a safe place now you will have two screws on the top of machine from where you just took the facia off and 2 underneath the bottom by removing the plastic kicker plate undo these and open the door to the right you will see 2 screws that hold the interlock in remove these and then remove the band around the door seal normally metal with spring now lift the front of the machine upwards and that will be the front off now unclip the door seal from inside and check for holes if ok soak in bleach over night and rinse in the morning try some descaler to remove and limescale when you use machine again total 10 screws to undo really easy goodluck and please leave feedback
SOURCE: hotpoint wf860 washing machine leaking
Had exactly the same problem and it did indeed turn out to be a blocked filter - mainly with "Colour Catcher" sheets. Initially I thought the dispenser drawer was faulty so spent twently-six quid on one before that failed to fix it and then I discovered this site!
To get to the filter, unplug the machine then remove the bottom plastic panel at the back of the machine (2 screws). Undo the jubilee clamp holding the black rubber flexible coupler that joins the drum, drain pump and pressure sensor to each other. Pull the black coupler downwards away from the drum. Inside is a plastic cup filter arrangement with a plastic ball. Clean this out of various debis - along with the sheets there was £ 2.26 (to put towards the cost of the drawer!) in mine.
SOURCE: Hotpoint Door Seal WMA64
I have reproduced the details of my article: http://www.fixya.com/support/t1543617-door_seal
here. I hope this will give you the information you need.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until it is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
