Your battery may be too flat and the electric clutch steals too much power and the ignition fades. Check the battery has water above the top of the plates, and try charging with mains powered charger overnight. Take great care to have the polartiy right, red to positive and black to negative. Do not touch any part of the metal frame with the clips as this can do damage or start a fire.
SOURCE: When I engage the mower blades, the tractor tries to stall
Besides the reverse switch, the seat switch will also cause this.
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
SOURCE: I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
