Question about Bunn VPR Coffee Maker
<!-- from fixya rte -->Keep the pot from filling too full - Bunn VPR Coffee Maker
Thomas Aldrin Nullas
    New Friend:
  • 128 Answers
Even the unit is off does the water still coming in causing overflow ?the causes are the ff :
1.the by quicksharer" in_rurl="http://i.display-trk.com/click?v=U0c6NjU1NjI6MTMwNDpzb2xlbm9pZCB2YWx2ZXM6MTdkOTI0ODBiZDUyZmJkYjA1MzBhMjdiMmNjZWYzNzM6ei0yMTQyLTc4NDM0NDp3d3cuZml4eWEuY29tOjE5ODI0NzpkZmVlMzU5N2UyMDM5ZWMyYjc0MWIzYzExZmVlODQ5NjpmMjEwYjFiMTFjZmU0YmFiOWE2Y2M1MmVmMGU0MWEzMDow&subid=g-784344-e42ee195296e4be18017130db046325f-&data_tagname=DIV" id="_GPLITA_6" rel='nofollow' href="#">solenoid valve'sKeep the pot from filling too full - arrow-10x10.png plunger maybe stuck in open position
if during the filling of the tank mode water overflows the ff is the problem :
2. ur water level sensor defective or the its surface coated w/scales
3. control board faulty
all of this must call 4 serivce
Posted on Oct 02, 2014
Hello. Bunn coffeemaker VPR Series. When water is poured in coffee starts to make. Carafe gets about 1/3 full and then just drips through filter for about 5 minutes. Never makes full pot.
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
Jul 20, 2017 | Bunn Coffee Makers & Espresso Machines
Cant start the coffee
VPS/VPR (VP17-3 are the same except it has 3 lower warmers) are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
Aloha, ukeboy57
Mar 28, 2014 | Bunn VP17-3 Coffee Maker
Will not brew
Make sure the coffee maker is full of water. Keep filling it till water comes out of spray head.. Should take two full pots plus 3/4 of another one. Wait for water to stop coming out of spray head. Now the unit should be ready to brew after it heats up.
Mar 29, 2013 | Bunn VPR Coffee Maker
Coffee has a tangy flavor
You need to clean the coffee maker.Use white vinegar.Just fill the reservoir with and hit brew.When it is done.Fill the pot half way with ice and one hand full if salt.Swirl the pot till all stains are gone.Then run one full pot of clean water,to rinse.Make yourself a fresh pot and enjoy.
May 16, 2011 | Keurig B60 Coffee Maker
I have a Bunn CWTF15. Water does not fill the coffee pot full anymore. Is there a float that needs to be adjusted? Would descaling help this problem? Thank you.
If u haven't cleaned it out using 3/4 vinegar to 1/4 water, some times this will happen. after running this thru ur coffee maker, (u won't believe the junk that comes out), then run full pots of water to rinse out (2x's). This should help it perform better.
Sep 12, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Apr 26, 2010 | Bunn 10 Cup Home Coffee Brewer
BT-10-B Bunn Thermofresh that will not heat or fill pot
Lots of times minerals clooect on the heating element and inside the heating chamber. The easiest thing to try is to put white vinegar into the filler, displacing some of the water into the pot. Leave this to soak for about an hour, then flush with several pots of water until the vinegar smell cannot be detected in the water. Make sure that the switch on the side is "ON". You may have an indicator light. The switch on the upper front is for the warmer. The reason you only got a partial pot of water is that the reservoir wasn't completely full. Once you have filled it completely, you should fet a full pot out for every full pot in. If all of the above gives you no relief, you may need to test the heating element for voltage and continuity. If it tests 'open', you will need to replace it.
Good luck, --W/D--
Jul 17, 2009 | Bunn B10 Coffee Maker
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Pumping more water out than what i put in
This coffee maker uses a resevoir tank system - the water you pour in pushes out water that is already heated - the water you pour in won't actually be used for that pot of coffee! For that reason you should only use full pitchers when filling. You may need to cycle through 2 or 3 fillings before the input matches the output once more. The capacity of the resevoir is about 3 pitchers; you can brew 2 pots in a row before the machine needs a break to bring the resevoir back up to temperature.
Nov 12, 2008 | Bunn VPR Coffee Maker
Coffee maker doesn't brew full pot
you must have a filter and coffee in the basket for a full drain.the weight of the water is enough to open the basket when its full but as your trail run ended the final amount of water is not enough to open drain drop. with filter and coffee in it there is enough weight to keep drain drop open so all water can drain!
Dec 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Bunn VPR Coffee Maker Logo
89 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
