The drive name itself is the clue to know whether it can burn dvds or not.
In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Please note that the formats of DVD and CD are quite different. Whereas a DVD drive can handle both DVD and CD, a CD drive can only handle cd formats. Furthermore, a drive that reads both formats does not necessarily mean it can handle the writing aspect ok. You need a drive that is capable of writing/burning DVD. Most drives that come along with pcs can only write CDs but able to read both. So check your drive to see whether or not it can write on DVDs ok. Good luck
Hello Rfd832, What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means CD-RW = Compact Disk-Read Write DVD-ROM = Digital Versatile Disk - Read Only Memory so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs) If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
