Unfortunately, they do not sell 'rubber' for phone antenna's separately. It would help me if you could provide a picture of the
antenna or even easier for you, reply with the brand and model of
phone we are talking about. Then I can look it up and see what kind of antenna it has. I may even have a brand new replacement
for it myself..
Thanks
The rule is the taller the antenna the better the reception and power output. Of course it is not always convenient to mount a 102" whip.
4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5-inch antenna.
You did not mention the signal on their meter and how close they are. This may be a modulation issue. Wattage increases can go unnoticed volume wise but small modulation increase can make dramatic changes in volume to the receiving radio.
Check that your dynamike or mike gain control is turned up clockwies increases it. The radio itself may need the modulation increased internally. If you have a powermike with adjustments on back it may be way to low. Hope this was of some help
The antenna is your problem not much gain. Height is everything tx and rx. Although it would not compare to a conventional cb size negates performance. Seeing is believing in this case hearing get adapter to connect to standard coax of antenna.
(PL259) to BNC Coax Adapter
Radio Shack sells them. And dont ask or buy any radios there. They are hardly the radioshack of choice anymore.
If you put 4 watts into a four-foot antenna, you will get the same power out of that antenna as if you were putting 2 watts into a 102-inch whip.
If you put 4 watts into a 3-foot antenna you will get the same power out as if you were putting about 1.5 watts into a 102-inch whip.
If you put 4 watts into a 7.5 inch antenna on a hand held CB, it would put out as much power as a third of a watt into a 102-whip.
If you put 4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
If you put 4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
If you put 4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5 antenna.
The best thing I can recommend is shop around on Ebay and hopefully find a basketcase Quest or Quest 2 with the antenna intact. Swapping the antennas is fairly easy. Lay the GPS display side down and remove the two endcap screws on the right side. Pull the old antenna out and to the right and replace it with the replacement antenna. Another option you may try is purchasing an external patch type antenna that can mount remotely and plugs into the back of your Quest GPS. Garmin WILL NOT sell you a replacement antenna. They want you to send it to them for repair and will charge you $100+.
Buy replacement antenna mast. Remove old one by unscrewing the retaining cap nut. Turn on the radio & let the antenna cable run all the way up while you pull on it to remove it.
Install the new antenna mast by turning the radio 'off' so the spool inside goes back to its beginning while you feed the cable of the new antenna down into the antenna mast hole.
Once the cable is all the way down, reinstall the retaining nut/cap and turn on the radio to allow the spool to run the antenna 'UP.'... cycle the radio ON and then OFF several times allowing the antenna to move all the way up and all the way down.
That's it!
Yes it is possible to replace just the mast/antenna part. You just need to goto a car audio place and get an replacement mast. The only other problem is if the the other half of the nylon piece is still stuck in the motor.
Take off the antenna nut that holds the antenna to the car and turn on the radio. The antenna should spit it's guts out, then position the new nylon lead in the same orentation that the old one came out, have an assistant turn off the radio and the antenna should get sucked back in. You need to be somewhat quick when doing the replacement part, sometimes you need to try a couple of times to get the antenna all the way in.
If it doesn't go all the way down there may be a piece of the old nylon string still stuck inside the antenna body.
