Question about Motorola Mobility DROID RAZR M Black Smartphone - Verizon Wireless 1.5 GHz Dual-Core Processor, 1 GB RAM, 8 GB Internal Storage, Android 4.0, 3G/4G, 8 MP Camera
How do I remove the battery for a Droid RAZR M phone?
Motorola Mobility
  • Official Brand Answer
  • 1,623 Answers
Hi
The Droid RAZR M is a non-removable battery device.And if you try to remove it, it is consider physical damage.
Please contact us to check your repair options.
Motorola Support Find Answers Motorola Mobility Inc
Regards
Marge
Motorola Mobility
Posted on Oct 02, 2014
How could I take out the battery from my Motorola droid xt912
Hello Sruly,
This product uses a non-removable battery. Any attempt to remove or replace your battery, unless performed by a service representative, may damage the product and void your warranty.
Regards,
Kenny
Motorola Support
Mar 19, 2015 | Motorola Mobility Droid Razr
Removing battery
This phone has a non-removable battery.
Mark
Motorola Support
May 15, 2014 | Motorola Mobility DROID RAZR Maxx 4G...
How to take the back of motorola razr maxx
Do not remove the back of the phone. The battery is not removable.
Mark
Motorola Support
Apr 25, 2014 | Motorola Mobility DROID RAZR MAXX HD
How to turn it on
The RAZR HD doesn't have a removable battery. The battery shouldn't be removed.
mark
motorola support
Mar 02, 2014 | Motorola Mobility Droid RAZR HD
Droid Razr won't turn back on.
For my two bits, try holding the power button a little longer, it might engage.
Jan 22, 2014 | Motorola Mobility DROID RAZR MAXX HD
How do i remove battery
http://gdgt.com/question/since-i-can-t-remove-the-battery-from-my-new-razr-maxx-how-does-one-reboot-my-phone-like-i-was-able-to-do-so-with-my-droid-x-i-know-i-read-something-about-it-zd4/
Oct 18, 2013 | Motorola Mobility DROID RAZR MAXX HD
Droid razr will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
How to remove a battery from Droid Razr
Ignore some of these my gently pop the back. Off thru the seam. U can do it with your nails. It's glued to the batter so. Use something like a. Butter knife and work it down thru but pushing up not. Down. You don't wanna puncture battery. Separate it from the battery. Then remove. The red. Rubber protector. Over the two. Screws St the. Bottom. Left I. Think. It is. Remove screws then use the tab that says pull to remove or whatever be careful. Not to tear the flex cable.... Those batteries aren't cheap
Aug 20, 2012 | Motorola Mobility Droid Razr
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Motorola Mobility DROID RAZR M Black Smartphone - Verizon Wireless 1.5 GHz Dual-Core Processor, 1 GB RAM, 8 GB Internal Storage, Android 4.0, 3G/4G, 8 MP Camera Logo
143 people viewed this question
Top Motorola Mobility Cell Phones Experts
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
