Garden Logo
A
Anonymous Posted on Sep 27, 2014
Hydrostatic mower won't go up hill
Is very hard to get going up hill especially from a standing start.
Dave Bisset
Level 1:
Scholar:
New Friend:
  • Contributor 71 Answers
  • Posted on Sep 28, 2014
Dave Bisset
Contributor
Level 1:
Scholar:
New Friend:
Answers
71
Questions
Helped
29981
Points
78
How old is your machine? I have a John Deere X300R which after just over 200 hrs got slow going upslope and then when hot would actually run back while on full revs and pedal right down hard. Contacted JD who said to get it "Lapped". Cost was $1,400 and likely to result in same again after another 150 to 200 hrs. This was a K46 drive unit. In the end I bought a K66 transmission and butchered the chassis to fit it. It is OK but I would not do it again as it cost about $3,000 all up and is not ideal. I am a retired manufacturing engineer so had the skills and gear. I suggest that your machine may be like mine was. I filled my new drive unit with synthetic oil, 15/40 grade and although expensive, I believe it is worth the expense. There is no quick or cheap way of overcoming the result of a defective drive unit that I know of.
5 Related Answers
Mike Squire
  • 420 Answers
  • Posted on Jul 19, 2010
SOURCE: my craftsman hydrostatic transmission dont want to go up hills
This symptom is cause most often by the following.
Worn and slipping drive belt which is separate from the blade/deck drive belt.(replace the belt).
by-pass lever (rod) not fully engaged (push it all the way in)
travel pedal or linkage is faulty or out of adjustment ( take to dealer)
Transaxle is faulty (take to dealer)
Anonymous
  • 3 Answers
  • Posted on Sep 28, 2010
SOURCE: I have a cub cadet model 1420 with hydrostatic
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Anonymous
  • 760 Answers
  • Posted on Oct 04, 2010
SOURCE: My MTD 12.5 hp briggs
You didn't indicate what model so I don't know if it is hydrostatic drive or not. If it is not hydrostatic drive, it is most likely a worn belt or clutch adjustment. If you don't have your manual you can download one here:http://www.mtdlawnmowerparts.com/manuals.php
If it is hydrostatic drive it stil could be the drive belt or low water in hydrostatic transmission, or even water in the oil in the hydrostatic transmission. Always list model number when asking questions.
Anonymous
  • 124 Answers
  • Posted on Dec 22, 2010
SOURCE: While using my Craftmas 17,5
My name is Dane and I'm going to help you with your problem. First, I believe those craftsman units are sealed and there's no way to actually check the hydrostatic oil level. So the first thing to do is make sure that you don'thave any leaks around the transmission assembly. If it looks clean and oil free, I would venture to say that it is more of a 90% chance that your drive belt is the problem, however it isn't from icing up, but rather from the heat of the extra work from the weight of the snowblower, causing it to slip. The belt isn't all that expensive and before I would get excited and start worrying about transmission failure, I would just replace the belt first, and rule it out. Make sure all your pulleys and tensioners don't have any loose hardware, and look alligned.
I think you'll fix the problem though just by the belt replacement. I hope I've helped. Thank you! Dane
Anonymous
  • 6468 Answers
  • Posted on Mar 29, 2012
SOURCE: hydrostatic drive gear YTH 1542
for not charging pull the cover off the top of the engine look for damaged wires mice love to eat them going slow i would check the belt for oil or see if its tight
Mower wont cut going up hill
there should be two drive belts. they should be replaced both at the same time. if one is wore so is the other one. use the correct belt, from a lawn mower parts store.
1helpful
Hydrostatic drive gear YTH 1542
2helpful
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
1helpful
2helpful
My MTD 12.5 hp briggs and stratton ride on mower is losing forward speed as though a clutch is slipping especially going up hills or slopes. MIKE
Oct 03, 2010 • Mtd Garden
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 • Troy Garden
Mower doesn't cut going downhill
Sounds like a loose belt check the tension spring if they ok check and see if belt is strectched
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
