Go to a hardware store and get a Dishwasher Hook-up Kit. It will include a flexible hose along with several adapters. You dishwasher should come with a drain hose. You will also need a 3-wire "pigtail" (an extension cord with no receptacle or socket at the end). Your dishwasher whould have come with installation instructions, but seriously, if you've never done that before (or done similar work before), you should call a professional installer or at least and experienced handy-man.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: installation
The incoming hot water can be hooked up independently. The thing you should consider is the drain line. The drain hose and the pump are (obviously) below the tub of the dishwasher (DW). If you route the drain hose through the floor directly, the water in the tub will siphon out. You'll need to route the drain hose to keep this from happening. The way to do that is to route it in such a way that it forms an almost upside down "J", then down through the island. The upper portion of the "J" should be about the same height as the top of the DW.
Also consider the electrical hook up. The proper way to wire it is through a SPST switch (like a light switch) so you can turn power off in an emergency or a servicer can kill power without having to locate the breaker. Some contractors "hard wire" the DW's in (with or without a SPST switch)... others mount a wall outlet so you can plug and unplug the DW if necessary. Either way is OK, only mentioned it so you'll know how your contractor will be doing it.
Just some things to consider. Good luck with the renovation and I hope you enjoy your new Kitchen.
SOURCE: hose does not fit on sink faucet
Yes, the adapter was the answer!!! I went to the Sears Service Center and bought one, under $10. HURRAY! And say hello to softer hands . . .
SOURCE: I have a portable
Yes, you need to know whether your faucet is male or female thread (threads on outside or inside) and buy an adapter that will fit into the faucet where the aerator normally sits. These are generally available in the plumbing section of your local hardware store. Make sure you know your diameters as well (O.D. stands for Outside Diameter and is usually male thread where as I.D. stands for Inside Diameter and is usually female thread)
SOURCE: after washing dishes in the kitchen sink, water
Hi, There is a drain hose under the sink that goes to the dishwasher. Make sure that hose is raised up higher then the drain pipe for you sink. It is just draining into the dishwasher because the drain hose is to low.
I hope this helps you. Please let me know if I can assist you further.
Vic
