After cleaning,with coffe bean full,the coffe grounds container is empty and clean...but the lamp is always on,and the machine can't make a coffe cup...
SOURCE: Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
SOURCE: keeps saying refill beans when it is full of beans
the float switch is stuck. need to clean it out.
SOURCE: Instead of depositing nice rounds discs of coffe
I had the same problem about a month ago and contacted customer services because its still in warranty - they suggested it may be the diffuser and sent a new one - which solved the problem. The attached invoice showed it as costing GBP 15.03 (although it was free under warranty).
SOURCE: I have descaled and cleaned
Sorry to read about your problem, I hope this helps you out.
run some more fresh water thru the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
SOURCE: spills half of the coffee into the machine .when
you need a part replaced and serviced 07779933829 uk
