2007 GMC Yukon XL Denali Logo
Posted on Jul 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cd changer won't play, load, or eject
2003 yukon denali cd changer won't play, load, or eject disc please help
  • Anonymous Mar 19, 2014
    cd changer
Anonymous
Level 2:
  • Expert 73 Answers
  • Posted on Aug 06, 2009
Anonymous
Expert
Level 2:
Answers
73
Questions
0
Helped
43787
Points
234
Had the same problem on our 03 yukon (not the changer but the main head unit) - have a 3rd party waranty and they replaced it. You can get the part for less than 300$ and it's easy to install.
2003 yukon denali fuse location for cd plaer
ON THE FUSE BOX LOOK DOWN TO THE BOTTOM AND FIND THE FUSE THAT HAS THE WORD INFO WRITTEN ON IT AS ITS FUSE PLACEMENT AND THAT WILL BE THE 15 AMP FUSE THAT CONTROLS THE CD PLAYER BUT BOTTOM RIGHT AREA ,IT WILL BE THE FOUR RIGHT BOTTOM FUSES YOU SEE BELOW . 2012-03-22_124606_06_gmc_yukon_denali_transmission_control_module_fuse.jpg
1helpful
2answers
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
14helpful
3answers
Hi what does Error 03 mean?
My endeavor has done this error 3 a couple of times and the cd changer basically shuts off all lights and won't do anything. Someone on another solution page said to slide a credit card back and forth in the cd opening to fix the problem. I've done this both times and it has made the changer play again as if nothing had happened : )
1helpful
CD player is not working.
I would first try removing the fuse to the radio/cd player, see if that resets the system and get the cd out.
Hope this helps some.
Matt
2answers
Rockford Fosgate cd changer
I have the same problem with the 2006 sentra
7helpful
2answers
2007 nissan maxima will not load or eject CD's...or even play the
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix this issue or, you can just purchase a new changer and save a lot of money.
Optiical error in car CD recorder
if you have children they may of placed change into the cd loading slot.
if not your optical laser lense is prob dirty.
go buy a cd laser pickup cleaner from best buy or radio shack. its a cd with fine hairs that clean the cd laser lense.
and do yourself a favor next time stop loading dirty cd's into you cd player.
CD changer problem
had to replace player twice, luckily it was under warranty. FACTORY PLAYER JAMS EASILY !!! What I have learned is to put cd player in radio mode before ejecting instead skipping form disc to disc.
2answers
Loading the cd changer on a 2002 Yukon Denali
Check the connections from the back maybe its connect good.
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
