A different app on my iPhone works well. Ipad tool has different appeared e
Did you check the Dual website, because there are many reasons why it would not work, and for most there is a solution on this link:
Universal Bluetooth GPS Receiver for Todays Most Popular Handheld...
SOURCE: problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
SOURCE: How do I sync my old iPad apps to new ipad?
You can use a itransfer to transfer files from iPad to the New iPad.
and this one can help you successfully transfer media files among all iOS devices, back up to PC
and iTunes, shift from iTunes and PC library to iOS devices, manage
media sources without iTunes.
SOURCE: Can't charge the ipad from the USB charger
To get Ipad to show as charging download Asus AiCharger from web and
restart computer after install.Plug in usb from Ipad and should now show
charging
http://event.asus.com/mb/2010/ai_charger/
Please Rate
You must turn on the tablet's Bluetooth radio before you can enjoy using any Bluetoothy peripherals. Here's how to activate Bluetooth on an Android tablet:
Open the Settings app.
On some Samsung tablets, touch the Connections tab.
Ensure that the master control next to the Bluetooth item is set to On.
Slide the icon to the right to activate.
When Bluetooth is on, the Bluetooth status icon appears. It uses the Bluetooth logo.
You'll also find a Bluetooth switch in the tablet's Quick Actions.
