Question about Fuji FinePix A360 Digital Camera
When snapping picture camera turns off finepix A360
Focus on item to be snapped snap camera lens retracks goes black hear mechanism but no picture
tace899
    Sergeant:
  • 291 Answers
Check your battery.
Posted on Sep 27, 2014
5 Related Answers
Anonymous
  • 217 Answers
SOURCE: Purple Screen
Your CCD imager is broken...
Posted on Aug 31, 2007
Anonymous
  • 6 Answers
SOURCE: Fuji FinePix F700
when downloading the pictures,good?.
then lcdconnecties are broken.
Posted on Aug 19, 2008
david
  • 244 Answers
SOURCE: Focus error on Fuji Finepix S5600
See my solution or email for help
Posted on Mar 10, 2009
Anonymous
  • 300 Answers
SOURCE: Power on to take picture, but view finder is dark,
Hi!
Probably the CCD is dead. It's a well known problem with S7000. It's a hardware problem, the CCD has to be changed. For S7000 it usually comes with the lens and it makes the repair quite expensive. It's about 250-300$ here. You should contact your local Fujifilm service center.
I work in a camera service center authorized by Fujifilm.
Sorry for the bad news!
Tom
Posted on Aug 01, 2009
Anonymous
SOURCE: Finepix adapter ring AR-FX3 55mm for Fugi 3800 digital
The ar-fx3 screws on to the camera and any lens screws on to it.
Posted on Feb 27, 2010
Camera is acting as though there is a lens cap over the lens. Cannot see pictures in LCD. All pictures come out blank (black). Can view pictures on the LCD taken on memory card previous to the...
yours is a broken CCD-chip - like ours.
hardly any good-used for the F700/710/810 avail anywhere
another new (used) camera is my best advice - repairing a busted CCD aint worth your time / money / efforts.
2answers
3helpful
2answers
Fuji (A360) lens won't come out
Lens mechanism is jammed. Probably the counter wheel attached to the drive gear is hitting the sensor and stopping it from working, so will switch off. Needs a service
Focus error message camera wontwork
I found this site to solve this problem. I got as far as tapping the lens, while turning it off. That worked but I still could not take pictures, so, I got the idea to put slight pressure on the lens when turning the camera on and was delighted to see that the error message was gone. Then, reluctantly, I snapped a picture...It worked. Hope this helps u 2..
Camera wont take snap
Because the camera has Mechanical Focus the camera button has 2 Pressures, Holding The first 1/2 of the button press will enable to Mechanical Focus to work, And then once the green dot is shown telling you its in focus, pressing the button all the way down will then take your picture !
Oct 25, 2008 • HTC G1
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Lenc cover will not open
Camera lens
Canon Ixus 40
My Camera has E18 Problem
Fuji FinePix A360 Digital Camera Logo
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
