I just want to know how to replace the rollers in a Canon ir3300 . I can buy the rollers, but want to know how to access the rollers to replace them (disasembling the Casette Feed Assembly.
SOURCE: Canon ImageRunner 2800 toner buildup
YES this parts is for cleaning purposes to collect toner that was building on the pressure roller .replacement of this assembly is needed if thick toner waste accumulates on the roller
SOURCE: Paper roller Problem
hi,
CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.canon.com/printer/prob676ijt65/solution
pow-e-r-3
SOURCE: Canon IR3750, jamming @ vertical feed out of tray
3 foam peices on lower right door assy put pressure on pinch roller assy, these foam peices lose their cushion and don't put enough pressure on the pinch rollers. Rather than order through MNf. I bought 10 feet of 3/8" wide 1/4" thick foam door/window weather stripping and cut length to fit (@9"), solves this issue wonderfully. (cost is $3-4)
SOURCE: canon mp250 paper will not feed snags on something
I had a paper feed problem with a Canon MP 250 and solved it this way. (not my own)
After many attempts t clean the feed rollers etc. I tried the following.
I cut a piece of card stock about two inches wide. I fed this sock from the front to rear and carefully worked the card stock in and out and from side to side (flossed it) and dislodged a drywall screw !!
I realize that having a drywall screw lodged in the paper feed is not common, however this "flossing trick may help to clear the paper feed path in other situations.
