you can set up Voicemail and then record voicemail message by following these steps:
1. Tap on Phone > Voicemail;
2. Usually, you will be guided to automated voicemail system and you can simply follow voice prompt to set up Voicemail. If not, you have to follow these steps:
a. Click "Set Up Now". You will be required to enter password. Tap password and then click "Done". Re-tap again and click "Done". Please keep in mind that password should be between 4-6 digits in length.
b. Click "Custom" to record voicemail. Activate "Record" to start recording and tap "Stop" to finish recording voicemail. After you finish recording voicemail, tap on "Save".
Press the voice mail button or dial the pilot for the voicemail, enter the password or ID your own extension (9+ext) on really old voicemails, then password, listen to the prompts or use the active buttons in the display.
To record voicemail on iPhone, you have to first set up Voicemail and then record voicemail message by following these steps:
The D1660 isn't an answering machine or a voicemail system. Please refer to the instructions for whatever answering machine/voicemail system you have on your phone line.
If you require further assistance feel free to repost your question, but please specify the make and model of the answering machine/voicemail system.
This is more than likely due your phone carrier providing you with a voicemail system on your phone that picks up before your answering machine. Depending on who you have you can call your own number from either another or your landline. Once you hear the message indicating that your voicemail box is full press the '#' key. If the mailbox prompts you for a password, enter the last 4 of your phone number. However if it doesn't prompt you, try the '*' key and enter the last 4 of your phone number as the password. If neither of these work then call your phone company and ask them to reset or remove the voicemail system, depending on your preference.
I usually see this system set up on phone systems that are provided by the same company as your internet service provider. In particular AT&T and Broadstripe both offer these kinds of voicemail systems and are usually activated when the phone system is activated as just part of the activation process. Feel free to comment, I'll watch this post to make sure you can get the help you're looking for, have a good day!
If you have an in-house administrator, they can log in and reset it. You might try 0000 and 1234 just in case, otherwise you will have to call whatever tech help you have and get them to reset it.
Are you able to Unlock the blackberry first, then try to call Voicemail?
You can try doing the following:
go to the phone dialer, click on the Blackberry Menu button
choose options
Choose Voicemail
There should be your number listed there.
Under password, put your password with a # afterwards.
Save and try to dial your voicemail again. It should automatically put the password in so you dont have to.
If you have an active voicemail... but have never activated it:
The default password is 0 0 0 0 (four - zero's)
The voicemail will talk you right through setting up voicemail, after the set up you can press 8 anytime you are in the voicemail to make changes to your account.
