Epson WorkForce WF-3540 All-in-One InkJet Printer Logo
A
Anonymous Posted on Sep 26, 2014
Can the glass in the display for Epson 3540 printer can be changed? Current glass broken
Can regular glass be used to replace broken glass?
Khizar Hayat
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on May 09, 2015
Khizar Hayat
Expert
Level 2:
New Friend:
Answers
72
Questions
0
Helped
43971
Points
140
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Oct 25, 2010
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
How do I change the ink cartridge in an Epson WF-3540 printer?
Follow the steps to change Epson printer Ink Cartridge:
    1. Turn on the printer
    2. Open the printer's top cover
    3. Wait for the print head to stop at the replacement position
    4. Open the cartridge cover
    5. Squeeze the tab on the back of the cartridge
    Read more steps to change Epson printer ink cartridge issue.
2answers
How to fix epson wf-3540 error code 0xFA all it tells me is to unplug then plug it in and still dose not work
Check the cartridges. Remove the cartridges and re insert it. sometimes bad contacts can causes such problems.
for more details check the link bellow
http://electro-medical.blogspot.com/
1helpful
Epson wf 3540 paper jam in adf and the mechanical system keeps on grinding in there. Is there a video somewhere on how to open the ADF and align parts in there
The ADF just pops open from the left side of the printer. There's some finger holes and just lift up the lid. As for grinding, it may be busted unless it got a sheet of paper in the gears.
How do I print envelopes on the Epson WF-3540 printer
Envelops can be printed per the software such as microsoft office. Depends on the program you use but if the software you use has this somewhere. sorry but it is a setting.
CD will not download
Download what you need from the Epson website.
3helpful
My workforce WF-3540 displays "PAPER JAM". I can find no jam
This sounds weird but I will post it since is solved this problem for me. Despite following all the instructions I could not get rid of the "paper jam" message on my WF3540 . In desperation I tried changing the yellow ink cartridge (which was low) and after the printer went through all its "new cartridge" routine - lo and behold the paper jam message was gone and the printer worked!
1helpful
Broken glass on touch screen display for epson workforce 845
The touchscreen is sold as one part, you can't buy or replace just the glass. There is a capacitive layer glued to the glass that is probably damaged.
1helpful
I can't change the print quality in excel for my Epson WF 3540
A driver component is missing meaning not installed good or not all the drivers for printer is installed.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
