Have to place foot on top of left side of deck to make it level..believe missing a support spring or something?
Makes and models vary considerably. However there are some things which apply to every unit. First check that your tyres are evenly inflated. If you have even slight slopes the lower side will press into the grass more and so cut deeper leaving a line. If the tyres are soft this is exaggerated. Best where possible to mow up and down slope. Next park on a flat surface like you garage floor. Carefully measure the distance from the outside of the mower deck to the floor. Measure the deck height with the unit in the cutting position. Best to do this on the rear edge of the deck where it just starts to be straight across the back. On two spinner decks, one is in front of the other so they can over lap without hitting each other. This means that the distance from the rear wheels can be different on either side. Three spinner units usually have the centre one in front. The deck swings up and down from the front attachment yoke. So the front of the deck will not rise as much as the rear. There are hangers which are lifted by the pedal which lifts the deck. If the distance to the floor is unequal, adjust the hanger threads until they hang evenly. I have not yet experienced a spring in any mower hangers.
SOURCE: 48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
SOURCE: cub cadet not cutting correctly on right side
Try sharpening the blade.Or the blade may be twisted.
SOURCE: 42" deck not cutting level
I had a similar problem, and the problem was fixed by airing up one of my front tires. This may not be all of the problem, but you should eliminate this before you go adjusting.......
Just a thought, --W/D--
SOURCE: the transmission will not engage,
it is possible that there are no parts missing - reach in and push the "rod end over the rear axle doesn't move the lever" lever forward - the brake is sticking in the "on"position - wiggle the lever back and forth, if it moves more than 1/4 inch, use a half inch wrench to tighten the nut holding the lever until the lever has only about 1/4 inch movement
SOURCE: 42 inch jd la115, hit stump in yard, changed blade
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
