clean saner then if
its not solve your problem check exposure lamp harness connections;
adjust the position of contact glassshading plate or clean/replace the
scanner home position sensor;replace the exposure lamp or inverter pcb
if needed; replace scanner board or engine board
1. defective exposure lamp or inverter board 2. incorrect shading position 3. poor contact on connector terminals 4. defective scanner board or engine board
this could be down the the scanner unit its self, Does the scanner move and light up - if yes could be logic board, if not the scanner unit is prob the fault. This would need a engineer to come and repair. depending where you live i have a few contacts in the UK that would solve this prob.
in my network i have hp M1005 printer always i'm getting this msg "scanner error 6 turn off then turn on" when i make turn off and turn on again same msg comming
