Question about Lakewood 200I Floor / Box Fan
My fan just stopped working. what would be the cause?
What causes the fan to quit?
Dirt mostly but hair is the number 1 stopper as it will wrap around the shaft causing it to stop working , if the fan got to hot and over heated this will also cause it to stop ! Try to spin the fan using your finger ( power off) and check if it spins freely if not a tiny amount of WD40 sprayed onto a small paint brush and then using the brush to add the wd40 to the shaft of the fan to free it up if hair is the problem wrapped around the shaft use a razor blade to cut it off if not turn the fan backwards unwrapping the hair .
Fan will not work in 1998 cadillac deville so no heat
1- check your fuses 2- if your thermostat needs to be replaced it can cause the fan to stop working because engine never gets hot enough to allow fan to come on. 3- your fan blower motor could be defective and needs to be replaced 4- your fan blower resister may need to be replaced. The fan will still work on high in most cars, but not work at all in others 5- if you have automatic temp control, the control panel may need to be replaced. These are expensive, so get a replacement at junk yard.
On my 2006 chevy trailblazer My heater fan stopped and I received a P1400 error code . What caused the fan to stop?
The P1400 code is a heated catalyst so what is causing your fan not to work is either your temp sensor or a faulty wire somewhere running to the fan. Check the fuse or relays
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_677dced97ad9bddf
1helpful
2answers
Auxiliary fan not kicking on (it has 2 fans, the driver's side cooling fan and the passenger side fan that runs intermittently that comes on when a/c or when heat is set to defrost setting stopped com
It won't cause any overheating, that fan is only suppose to come on when the a/c is on. Since it's cold, it's not going to come on because the engine has at least 2 sensors that tell the temp and it can see it's not needed. Now, if you turn it on during the summer and it doesn't come on and your a/c doesn't work, you may have blown the relay or your a/c may be low/out.
1helpful
WHAT CAUSED MY CONDENSER FAN TO STOP RUNNING
If the refrigerator is running without any other problems, then just replace the fan motor. Here is the fan and it is only $36.80. No where near $100.00!
1helpful
Compressor works but compressor fan does not
It is possible the capacitor has gone bad, cause, possibly a power surge. Suggest replacing capacitor first and see if problem happens again then I would change fan motor and capacitor. Good luck on your repairs
Dave
1helpful
Satellite A215-S7444 laptop's fan is no longer working. Was working earlier. What do I do to fix it?
If the fan was making a bearing noise and has stopped spinning then the fan needs to be replaced.
The fan may have stopped spinning because it is clogged with dust, if so loosen with a still brush and vacuum to remove the dust.
A faulty fan will cause the CPU to overheat and shutdown the computer and will not start up again until it has cooled down. Continue to ignore this it will eventually cause the CPU to fail.
Picture is really dark
i think nothing other than the lamp could be causing the problem, is the fan actually out or you just suspect it stops working. Is the lamp an original sony lamp? some outfits that supply the replacement lamps just go by the physical shape of the lamp(round or square?)it might be you got the wrong lamp for it.If the fan is not working then the heat of the lamp could cause some light engine damage, could be an expensive repair.
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Lakewood 200I Floor / Box Fan Logo
Top Lakewood Dryers Experts
Jay Finke
Jay Finke
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
