I am using wifi Samsung tablet and a wifi vsus laptop Computer.... to print ledgers.....has worked in past.
SOURCE: Problem in wireless connection.
ok First Didnt say what operating systems you were running 2Have you updated from windows SP2 let me Know ttech
SOURCE: WiFi Print Server, how do I configure?
I purchased this machine and went through two months of technical support, new drivers, uninstalling and installing software, new install cd from HP (that was older than the one that came with the machine) then finally a replacement printer - still no wireless capability with my compaq v2000.
Chased it all the way up to US senior support and a woman told me there that the wireless peer-to-peer feature only worked 50% of the time. She told me to buy a router - end of story.
I'll never buy another HP printer again, and I'll never spend the money on upgrading to peer-to-peer wireless for a printer again!
So - get a router and follow the instructions, and it'll probably work.
SOURCE: PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
SOURCE: HP CLJ 2600n printer seems to be recognized on the
Check if the printer is shared on the server.
Good luck
