Question about Brother IntelliFAX 2800 Laser Fax
All day yesterday... about 40 from me all came back Busy / no response. Turned it off , checked the plugs. Turned it back on. No error messages on the machine itself. Any ideas?
SOURCE: Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Posted on Mar 26, 2008
SOURCE: fax busy, no response yet fax is sent ok
NG or poor line condition on the transmission report means that there is interference on the phone line.you need to double check the quality of the dial tone-if it static or clear.now,other interferences could be caused by other devices on the same line as your fax such as DSL modems.make sure first that you connect the brother machine directly to the walljack and try resending a fax.modem settings can be changed.e-mail me if you need that info
Posted on Nov 19, 2008
SOURCE: beeping sound when try to fax. report says busy/no response
hi,
check it out weather it is in fax mode not in phone mode
Posted on Dec 15, 2008
SOURCE: Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Posted on Jan 09, 2009
SOURCE: I can't fax! BUSY/NO RESPONSE
If you're dialing a long-distance number and you did not (like me sign up for a long distance package), the phone company may have disabled long-distance calling capability. You should still be able to send to 1-800- fax no.s. Using Calling cards works too. See comment on posting from mark_heinze on Jan.18, 2009.
Posted on Jan 24, 2009
