Question about Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le
Where can I get my laser level model RT-7210-1 repaired?
1helpful
2answers
I need my Unit rebuilt, unit was knocked over and the bearings fell out.Can this be done?
Unfortunately no. Nothing you do will make this accurate again. These are throw away lasers.
Laser level problem
I had the same issue. The laser would only turn on intermittently and mostly not turn on at all. Since the green led would come on for 2 seconds when you first turn the rotary laser unit on (as per the user manual) I decided that the problem was probably with the remote. I took it apart (4 screws) and cleaned the corrosion off of the battery contacts on the slider switch and the two plates that the switch sliders make contact with. I also bent the two thin slider contacts so that they would contact the corresponding plates on the circuit board with a little more pressure. Put it back together and that seemed to fix it.
1helpful
2answers
Dropped rt7210-1 bearings out laser and drive ok
Dropped my robolaser RT7210-1 and the bearings came out.
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
I have a RoboToolz RB01001 rotary laser. The green light comes on for approximately 2 sec. then goes out and the unit does not function at all. It has very little usage and has been cared for, never tossed...
That's usually a battery problem either in the laser unit or the remote control. The battery in the remote tends to disconnect if bumped. A small piece of foam pad at the bottom of the battery can fix that.
Does not power on. batteries new
check batters ports see that they are clean
1helpful
Need robolaser instructions; can not get it to turn on. it has new batteries.I really don't know anything about this laser. It was my Dad's he has passed away.
Did u open the front and turn on the remote to activate the laser ? the model i have ( 8years old )this is what it takes to get the laser work.
Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le Logo
Top Robotoolz Measuring Tools & Sensors Experts
ADMIN Canada
ADMIN Canada
ray gallant
 Mikey
Mikey
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
