Question about Microsoft Windows XP Home Edition
Vaio vgn-fs415m hi everybody.how to change fat32 to normal one,cz i lost 73 gb of hard drive memory.tnx
Posted by deivis on
Anonymous
    Sergeant:
    Champion:
  • 306 Answers
Just go to the Command Prompt and execute the command: C:\> CONVERT C: /fs:ntfs Where C: is a name of the drive you want to convert. After machine re-boot conversion process will start and you'll have your FAT32 converted to NTFS without of data loss.
Posted on Nov 10, 2007
  • Anonymous Nov 10, 2007
    Thats the correct way to do it...if it fails is it do to a faulty OS and youll need to format and reinstall windows and select NTFS
Sony Vaio VGN-SZ18GP Windows 7 shutdown problem .... when I shut down .... it gets stuck on the screen of shutdown but the "loading circle" is still running
This can be a sign of a memory failure, either the RAM is not clearing or the hard drive is on its' way out. Hold the power button down for 6 seconds for a "hard shutdown". Then restart and see if the problem persists.
Oct 13, 2013 | Sony VAIO VGN-SZ18GP/C, VAIO VGN-SZ420NB,...
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
How much memory can a ASUS K501P accomodate?
ASUS K50IP vs SONY VAIO Sony Vaio VGN-SZ44GN? Sony: Processor Speed: 1,800 MHz
Hard Drive Capacity: 100 GB
Memory (RAM): 1,000 MB
Chip Type: Intel Core 2 Duo
Primary Drive: DVD+/-RW
Laptop Size: 13 inches
Features: 10/100 LAN Card, Firewire, Modem, USB, Wireless Network Card
ASUS:
Processor Speed: 2,200 MHz
Hard Drive Capacity: 320 GB
Memory (RAM): 2,000 MB
Chip Type: Intel Pentium Core 2 Duo
Primary Drive: Dual Layer DVD
Laptop Size: 15.6 inches
Features: 10/100 LAN Card, Carrying Case, Modem, Operating System, USB, Wireless Network Card
Mar 19, 2011 | Computers & Internet
Hi I'm llokig for a new hard drive for my vaio vgn t1xp but having difficulty as it is very small nad has a funny connector!
Hi there.
There are normally 2 kinds of hard drives in laptops at the moment apart from solid state HDD's which are mainly in Acer Onebooks etc.
2.5ins IDE HDD which looks like this >>>>>>
2.5ins SATA HDD which looks like this >>>>>
It will be one of these type of hard drive which goes into the Viao probably the SATA HDD.
Good luck and thanks for using FixYa!!
May 24, 2009 | Sony VAIO VGN-T1XP/L Notebook
Sony Vaio vgn-cr520e
hi hears a link for sony vaio driver utilty page
http://support.vaio.sony.co.uk/submenu/downloads.asp?site=voe_en_GB_cons
hope i was helpfull
good luck
Mar 18, 2009 | Sony VAIO VGN-CR520E/J
MEMORY UPGRADE
from the white page I found:
"The 17-inch widescreen Sony Vaio VGN-AR230G, the first entertainment Sony’s AR notebook with Core 2 Duo Mobile (Merom) processor, is now available at SonyStyle.com. The Vaio VGN-AR230G comes with a T5600 (1.83GHz, 2MB L2 cache) CPU, an 1GB DDR2 SDRAM (expandable to maximal 2GB), an 200GB 4200rpm SATA hard drive and a dual layer DVD burner ."
There u are, only 2GB.
/Teis
Dec 29, 2008 | Sony VAIO VGN-AR230G Notebook
Memory installed in laptop sony vaio VGN-NR498E/E
You can go to www.crucial.com and use their Memory Configurator to figure out how your memory is lined up.
Jul 09, 2008 | Computers & Internet
Sony vaio vgn-fs415m
following art some options you can try
Buy new windows software
Give me your mail i can give you
Sony laptop has already windows on recovery , you can go through >start
>all program
>sony vaio recovery
then chose accordingly
Nov 19, 2007 | Computers & Internet
Microsoft Windows XP Home Edition Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
