Question about Nintendo Wii Sports for Wii
Error message when in wii sports
Error message says remove disc turn off power to console for a while, clean disc, consult manual
Posted by CAROLYN LUDWIG on
5 Related Answers
Anonymous
  • 53 Answers
SOURCE: wii console error
Is it just one game that does this? Does it happen in the middle of a game or right away? Is the game an import?
I would call Nintendo on this one.
Posted on Mar 24, 2008
gamerfixer07
Wes Sydenstricker
  • 344 Answers
SOURCE: wii keeps giving error message
Have you tried unplugging the unit for about an hour then testing it again but in a different position? If that doesnot work it is most likely a laser failure and you will need to get it serviced.
I hope this helps. Good luck to you.
Posted on Aug 04, 2008
Anonymous
  • 16 Answers
SOURCE: Error message when disc inserted into Wii
it migth be upside down game broke or it is a burned disk and it can not be used anymore can u help me with my wii promlem too here is my problems link
Posted on Aug 22, 2008
Anonymous
  • 1019 Answers
SOURCE: We are getting an error message everytime we load a disc
Try the following options.
1:) Soft Reset:- Press the reset button on the Wii console For 2 seconds.
2:) Hard Reset. :- Unplug The Wii Console For 5-10 Minutes. As once unplugged it resets itself.
3:) use a CD/DVD Based laser head cleaning disk, to remove any dirt/dust from the laser unit.
Thankyou For Using Fixyas Free Forums.
Mike @ compurepair.
Posted on Nov 30, 2008
Anonymous
  • 26 Answers
SOURCE: Wii console won't read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving Disc Read Error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the Problem Yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Feb 20, 2009
Game has error, says to consult Wii operations manual
It's most likely the disc that is causing trouble. If all of your other games work, it the game you bought. I had the same problem with MySims Party, I went to the store where I bought it, they gave me a new disc, which worked fine.
2answers
My wii won't read discs
Made a video showing how I fixed this exact problem on mine.
Wii error remove game turn power off consult manual for troubleshooting have no manual help!!!!
Does this happen for all Wii games you have? Or is this just 1 Wii game you are getting this error message with? If it's just 1 game is the disc damaged? Please repost the answers to the questions i asked.
5helpful
2answers
Nintendo wii message reads: error occured remove disc turn off console check operations manual for information! on 2 new games
Some older Wii units also have trouble with Dual Layer Discs, which pack more info onto a disk like Super Smash Bros. Brawl and Metroid Prime. If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. the other resolution for this is to change the laser on the system but it will cost you for that. Try to clean the lens first it might read the new disk.
Thanks for using Fixya.
Code error 32022 what is it
Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check whether the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on. If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately.
Click here to download Ninento wii repair guide
Error message error occurred. press the eject button and remove the disc. turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check wheather the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on.
If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately. Remove the AC adapter's AC plus from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
http://igotwii.com/nintendo-wii-manual-error-messages-page-68-69
Keep getting error message,remove disc and turn power off
Remove the AC adapter's AC plug from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
2helpful
Mike @ compurepair.
Ninteno wii
Make sure the discs are clean, make sure you are putting them in the right way, other than that you might try some sort of lens cleaning disc.  Also, make sure your Wii has the latest firmware update.
Open Questions:
See all Nintendo Wii Sports for Wii Questions
Nintendo Wii Sports for  Wii Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Aron
WTF Chuck.....
WTF Chuck.....
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
