Question about FindingKing Grandfather Clock Pendulum Rod Suspension Spring Tool
<!-- from fixya rte -->How do I start a grandfather clock - FindingKing Grandfather Clock Pendulum Rod Suspension Spring Tool
Posted by cheryl Silzer on
Louise Ames
    New Friend:
  • 28 Answers
Usually with a key or winder
Posted on Sep 27, 2014
2answers
Daneker grandfather clock
Yes chiming clocks always have a switch to turn them off. Often termed a 'night shut off'.
https://www.google.com/search?q=daneker+grandfather+clock+turn+off+chimes
Nov 07, 2021 • The Watches
Grandmother clock
If you're moving your grandfather clock by yourself, use a dolly to take the carefully packed timepiece out of your home and to the moving vehicle. Tilt the box as little as possible when loading it on the truck. Use straps to secure the clock case, so that it won't slide, slip or tumble down during the transportation.
If you are not sure how to transport a grandfather clock, you'd better keep it in an upright position during transit. Newer grandfather clocks can be moved lying down but this puts unnecessary pressure on the panels and glass elements, increasing the risk of breaking. Older clocks need to be moved upright because of the weight of the movement and the way it is attached to the case.
Do you want the hottest new Apple Watch?
Collect 100 Points and get an apple watch now. New offer for United States Only.
Copy this gg.gg/an-Apple-Watch-Now and past in your browser.
Nov 04, 2019 • The Watches
1helpful
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 • The Watches
Ethan allen grandfather clock manual
I need a manual for this clock , please
Mar 25, 2013 • Watches
G.E. Grandfather clock The Adams
I assume you have looked on the Internet to find the manual. Even with all the trillions of things you can find, probably no one has uploaded that manual yet. I had a clock shop for over 30 years. Most grandfather calendar dials can be set by using a NEW pencil eraser. Try to use it near the center of the dial, not on the outside edge. Move the dial clockwise. I suggest a new pencil eraser because a used one can leave smudges on the dial.
Oct 30, 2017 • Watches
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 • Watches
4helpful
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 • Watches
3answers
Grandfather clock doesnt seem to be ticking and pendullum wont swing
That just happend to my great grandmother. You need to ask a clock maitnace person. Because it might Be you just need grease or a new motor so you also have to see if it' something that you want to fix an keep or get rid of.
Nov 11, 2008 • Watches
How to clean a grandfather clock's mechanism
The Best Thing You Can Use Is Mentholated Spirits Cleans Really Well
Jul 04, 2008 • Watches
FindingKing Grandfather Clock Pendulum Rod Suspension Spring Tool Logo
Top FindingKing Watches Experts
Ekse
Jimmy Accardi
Are you a FindingKing Watch Expert? Answer questions, earn points and help others
