Question about Apple iPad (16 GB) WiFi Tablet PC
HELP PLEASE!! My IPAD Mini is stuck/frozen. I can see the wallpaper background and the slide to turn on IPAD but it wont slide to turn on. When I hold down the sleep/wake to shut it down it goes to th
HELP PLEASE!! My IPAD Mini is stuck/frozen. I can see the wallpaper background and the slide to turn on IPAD but it wont slide to turn on. When I hold down the sleep/wake to shut it down it goes to the slide to shut down at the top of the screen and cancel at the bottom as usual but it wont slide to shut down. I tapped many times at the cancel button and it finally cancelled and went back to the slide to turn on and it wont budge. Is there any way to fix this??
Posted by Susan Marie on
  • Cathy
    Cathy Nov 02, 2014
    Setting, general ,accessibility , or tell Sri to turn off voice over off
Cathy
    New Friend:
When to apple store tap 3 time on screen will reboot and go to setting general and accessibility voice should be off or tell Siri to turn off voice over that what apple tech did it working fine
Posted on Nov 02, 2014
NavShack
    New Friend:
  • 65 Answers
Try removing the battery for 30 seconds.
Posted on Sep 26, 2014
5 Related Answers
luis224
Luis Hindman
  • 22 Answers
SOURCE: my iPad. Screen is locked
What part and how-go to my service pages and my team will be on the job
Posted on Dec 28, 2011
Anonymous
SOURCE: iPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Posted on Jul 16, 2012
charleybank
Charley Brown
SOURCE: IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Posted on Jul 19, 2012
Jim Thomson
  • 1099 Answers
SOURCE: On my new iPad 3, when I push the home button to get out of a program, it does not work. I push & hold and nothing happens. I have rebooted the iPad several times, nothing. What should I try next.
It may be a hardware fault, what I would do is given that it is a new ipad take it to the local Apple Store and they will either replace it and have it repaired.
Posted on Dec 11, 2012
Anonymous
SOURCE: My ipad mini keeps shutting off
I would first try doing a hard reset. Hold the home and power button down simultaneously until the iPad completely turns off and the Apple logo appears. You can ignore the slide to turn off button when it appears.
If that doesn't solve the issue I would make an appointment with your local Apple Store and have the device checked out by an Apple Genius.
Hope that helps!
Posted on Mar 22, 2013
Mac Mini Ipad Locked screen?
Press and hold down the Home button on the front of your iPhone, iPod touch, or iPad while still holding down the On/Off button. Keep holding both buttons as the screen turns off keep holding both buttons until the turns back on again and displays the Apple logo
Nov 26, 2015 | Apple iPad (16 GB) WiFi Tablet PC
What would make my ipad just light and i can't get anything on it?
Try restarting your iPad. To do this, simply press and hold the Sleep/Wake button until a red slider appears; then slide the slider. To turn back on, press and hold the Sleep/Wake button until the Apple logo appears.
If tip above does not work, try resetting your iPad. To do this, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo.
If above tips do not work, the issue could be that the battery is fully depleted. Plug it into a wall outlet for a while and see if your battery holds a charge. Please note that it can take up to 20 minutes of charging before the iPad will start up.
Nov 17, 2015 | Apple iPad Mini
I was using my iPad this a.m. but this afternoon, it was frozen-up
This works on the Kindle. Try it with the iPad ---- turn off the device, wait for a few seconds, then turn it back on.
Apr 10, 2015 | Apple iPad 32 GB 3G Tablet PC
How to reboot an iPad, a video clip is stuck on running
Rebooting is easy. It is called a hard reboot. Just hold both buttons down until you see a red slider, and then slide it to shut down. It will restart, and you will see the Apple logo.
Oct 30, 2014 | Apple iPad 64 GB WiFi
PLEASE HELP my iPad 4 wont re-boot. after the apple emblem it shows a small circle with itunes in it and what looks like a cord you use to charge a iPad if you touch it or try sliding it nothing happe
Seems that your iPad has been reset to factory. You will have to plug it into your computer and launch iTunes. From there you should be able to restore from your previous sync. It helps if you use the computer you originally set up the iPad with.
Jul 03, 2014 | Apple iPad 32 GB WiFi Tablet PC
Why is my apple ipad not responding
Hold the menu button while pressing the power button. It will reset.
May 18, 2014 | Apple iPad Mini
My I pad mini froze, what can I do to fix it?
Hanging/ Freezing iPads is not rare. It can really bound to happen even the device is idle. (for me.) All I can think of is that considering holding the power/sleep button of your iPad, to make the device shut down. Or sometimes holding the button can recover the frozen iPad. (Happened once for me.)
Jan 10, 2014 | Apple iPad Mini
Touch screen frozen
Hold the home and power button together until the screen goes off
Nov 14, 2013 | Apple iPad Mini
Ipad mini is frozen wont turn on or off cant get into it at all
Hold the power and home buttons at the same time to hard power down. Wait 10 seconds and turn it back on.
Sep 10, 2013 | Tablets & eReaders
My Ipad Mini keeps shutting off automatically, then turns back on. When the home screen is shown it just keeps glitching and shutting off. Whats wrong with it?
Hope that helps!
Mar 22, 2013 | Apple iPad Mini
Apple iPad (16 GB) WiFi Tablet PC Logo
235 people viewed this question
Top Apple Tablets & eReaders Experts
John mullen
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
