My parrot is perfect paired, and detects fine my iphone. it worked once perfectly.
SOURCE: can't get contacts to work with parrot 3200ls & nokia N95 8GB
hi, try using the object push in your settings. this happened to me and i had to install a program from my work and then object push. worth a try.....
SOURCE: Unable to connect my iphone 3gs to the Parrot CK3000 Evolution.
You need to reset the Parrot first.
Hold down red and green buttons together until she tells you that the
memory is being cleared. Then she will prompt you to pair your phone.
Then, and only then does the Parrot allow the iPhone to pair, and it will bring up the code prompt for you on the iPhone.
You won't find this written down anywhere on the Parrot site.
SOURCE: Good afternoon, I have a Parrot CK3200, and a
If you have had the parrot a long time you will need a software update, this can be done from a laptop with a bluetooth dongle. Try Parrot.com/support you can also try sending the contacts via bluetooth to the parrot one by one.
SOURCE: I have just bought a new apple I phone 4. I can
remove all the previous paired phones from the parrot memory and then try again. if this dont work then you will need to have the software of the parrot updated. You can do this yourself but you will need a laptop with bluetooth. then download the software from parrot web site.
SOURCE: When trying to pair iPhone
try removing all previous phones fromt he parrot memory and try again.
