We have seen some success with this issue by following these instructions. Please try this procedure one more time using the instructions below.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the issue persists, the hardware itself is malfunctioning and will require service
Steps to Fix Epson Printer Error Code 0xEA:-
Following these procedures using the given below instructions to solve the issue quickly.
Step 1:- Turn Off the Epson printer
Turn the Epson printer off, and then disconnect the power and the USB cable is connected.
Step 2:- Open the Epson Printer
Then open the Epson printer cover, then verify for any torn or jammed paper and then remove it.
Step 3:- Turn On the Epson printer
Now, reconnect the power cable and turn the printer back on.
Step 4:- Press "Copy" Button
Next, press the "Copy" Button and see if the unit responds.
Step 5:- Verify That All Transit Tape
If the printer is displaying the Epson Printer Error Code 0xEA, then please check that all transit tape or foam blocks have been removed from inside the printer.
Then open the printer and look inside to ensure that there is no material such as tapes, or anything else which is stuck.
If You Still face issue visit us, we'll help you from the scratch: Epson printer error code 0xea
Toll-Free No- +1-888-209-3034
