Question about Canon PIXMA MP610 InkJet Printer
Black ink is skipping lines
All colors seem to be working fine except the black when printing a whole page it prints about 1/2 inch and then skips a 1/2 inch, repeats this down the whole page
Neal Doherty
    New Friend:
  • 13 Answers
Take out cartridge put in a sandwich baggie and shake it; then re-install
Posted on Sep 26, 2014
5 Related Answers
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Posted on Mar 24, 2008
Priya darshan
  • 3422 Answers
SOURCE: Black print is skipping
Did you try runing a nozzel check?Please try out once and let me know.
goto to start-> settings->printers and faxes-> select your printer->right click->properties->tools-> find options like clean cart or nozals.
check printer settings for best ,normal,or draft set as best and try. may helpful.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 11, 2008
acdr
kishor khatri
  • 1913 Answers
SOURCE: printing problem
refix ink cartridge clean it then check.
Posted on Jan 05, 2009
Anonymous
  • 71 Answers
SOURCE: changed black ink cartridge to LD brand. Now
Canon printers do not like non Canon inks. Maybe other printers have similar issues but it seems that Canon is particularly finnicky.
Posted on Jun 20, 2009
nadirsalim
nadir salim
  • 185 Answers
SOURCE: Black ink not printing. Will print a page fine
Seems like Black cartridge is either empty or clogged. If you are sure that cartridge got ink in it then remove it and soak (surface only) of the head into hot water for about 15 seconds and test it by rubbing the head onto a cloth. If no ink comes out then try again.
good luck
please vote so I can continue sharing
Posted on Nov 09, 2010
Black ink not printing. Will print a page fine that has color on it. If just black text on a page it is very light and sometimes skips every 3rd or 4th line
good luck
Nov 09, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printer seems to be skipping
As the printer is printing fine from word......try to print from notepad and wordpad also.
If it prints fine then it is a problem with internet explorer or it can be also a problem with a particular website.
If you are facing the same problem with all the websites then try reinstalling Internet Explorer.
May 24, 2008 | Dell 922 All-In-One InkJet Printer
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
HP psc 2175 skips when "copy"
replace the black print cartridge. I guess that the text is B&W. Pictures are printed in color - from the color ink cartridge.
Mar 20, 2008 | HP PSC 2175 All-In-One InkJet Printer
Cannot print in color on HP OfficeJet 9110 All-in-One
Nothing to do with the driver, I'd say the cartridges are your problem, skipping lines and missing colour are indications of needing new ink carts, are carts new HP ones?
Jan 19, 2008 | HP Officejet 9110 All-In-One InkJet...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
A faded line prints across the page
The imaging bar has speck of dust on it.
Turn printer OFF.
Open the printer. Pull out the transfer roller. Should have a big green handle. Do not touch the roller.
Look inside for a shiny rectangular block about 5inches x 0.5 inch.
This is the imaging bar. Using a lint free cloth with no chemical and no water, gently wipe this bar to remove any specks of dust/paper specks.
Put roller back.
Close the printer.
Turn printer ON.
Problem fixed.
May 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Canon PIXMA MP610 InkJet Printer Logo
698 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
