Moved from Cars and Trucks category to Snapper Ride on Mower.
Breaking or falling off is a pulley or pulley alignment issue, or a tensioner issue. Belts are just ordered by make and model specs. Don't sweat the details on length.
J, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
To start with, the easiest way is to remove the mowing deck from the tractor. It will really be tough if you don't or can't. You may need an owners manual to guide you through all the steps.
1. Remove the cutting deck from the tractor 2. Work the old belt off (if not broken) the mandrel pulleys and idler pulleys 3. Pull the belt away to reinstall a new one 1. Work the new belt around both the mandrel pulleys 2. Make sure the belt is in all the pulley grooves and inside all the belt guides 3. Now you have to reinstall the mowing deck. Here are some diagrams that should help you. http://www.ereplacementparts.com/bolens-13am762f765-2005-lawn-tractor-parts-c-27272_27390_27402.html
Go to ... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number on the left that is under the seat and all the different diagrams are there. Click on Mower Deck.
