I click on New Group, Add members, From Outlook contacts, type the name, double click and the name shows up at the bottom and on the group list. They I click on Save and Close at the top and sometimes it saves and sometimes it doesn't; I often get the message that I can't save it since someone else is using the name or the program - I'm defeated and frustrated!
SOURCE: change display of contacts to first name, last name in outlook 2003
In most phones, there is an 'options' or 'preferences' in the address book that allows you to sort by first name, last name, etc.
As far as Outlook goes, when you are in the contacts tab, there is a link on the left that says "customize current view". Click on this and you can select fields to pick what fields you want displayed or select sort to pick how they are displayed.
SOURCE: addresses in outlook express
When adding Contacts to your Outlook Express, add the Display Name and Email address (double check that the email address is accurate) then, press the save button at the bottom of the screen on the right hand side. By pressing the Add button, you are telling the program that you wish to add a second email address for this person (Contact) and this may be what is causing your issue when trying to access contacts. Give it a try and if it works, please rate my response. Thanks!
OpenSource13
SOURCE: MS Outlook Contacts error solution
This error may be occurred due to improper installation of Outlook, or because of some setting errors. so make sure the outlook installed properly or not. If in some case you got PST error in outlook you can take help from the website : http://www.inboxpstrepair.com
