After entering my code and enter, the spinning icon appears and also the progress bar. It moves about an 1/8th of the way then disappears and computer shut down
SOURCE: powers down shortly after boot
Thank for contacting Fixya, I will be glad to assist you.
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Mac to start up.
• Please update me to let me know if this works.
Thanks.
-The MacTechTrainer
The scroll on your laptop is controlled by the trackpad installed on the system.
If you are having problems with the scroll on your laptop's trackpad, there is something you can do before you take it into a computer repair shop.
Updating the driver to the trackpad will enable the scroll if it is not working at all.
Once the driver is updated, your scroll should work again.
You can access the driver through the Device Manager on your laptop.
Click the "Start" button, then click the "Search" option.
Type "Device Manager" into the search bar and press the "Enter" button.
Click on the "Device Manager" icon from the menu, then scroll down to the "Track Pad" icon on the left side of the screen.
Click on the icon, then click the "Driver" tab at the top of the window. Click the "Update" driver option from the window.
Wait for the new driver to install on your computer.
This should take about two minutes to complete.
A window will appear telling you that the driver has been installed.
Put your fingers on the touchpad to move the mouse around on the screen.
Hope this helps.
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
press the reset button
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). Where the only thing that are working are the keyboard, mouse and files When the repairs are done, restart the computer, and allow it to boot normally.
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains
software that allows you to repair, restore, or diagnose almost any computer
problem also has a bios reset tool which can remove your password and bios
password
you will have to burn it to
a disk as an ISO then you will have to
boot from the disc During the boot process you will see on the screen to press a certain
key to enter setup Press and hold that key during the boot up process to enter
BIOS the scroll down to advanced bios features press enter change your first
boot device to cd press escape then press f10 to save to cmos to restart (note
after you have removed your password you will have change first boot back to
your hard drive)
Hope this helps
