The picture goes black then after power on & off and several attempts the pictures comes back but eventually turns black again.
Tv repair dubai is an independent television repair company with a team of professional technicians that have been certified by Samsung, Panasonic, LG, and many other well-known brands. We also have the latest technology in the field of television repairs. To get Tv repair in Dubai call now our helpline number at +97145864033.
Posted on Oct 31, 2022
SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Posted on Apr 04, 2009
SOURCE: When I push the power button on my RCA HDTV
Sounds like the bulb went out.
Go to http://www.purelandsupply.com/RCA-Projection-TV-Lamp.html and order a new bulb for under $200.
They are easy to intall; a screwdriver and 10 minutes.
Posted on Jun 24, 2009
SOURCE: I have sound, but no picture
I am finding a lot of people's lamps are going out. This maybe your problem too judging from what I have read above.
There are replacement lamps. They used to be pretty expensive but they are somewhat reasonable now. Below is a site you can order a new lamp this should fix the problem.
But before you order make sure that all the cables in the back of the television are in the right order. Red and White are audio while Yellow is video. A lot of people are unable to distinguish the yellow from the white.
If you have the other cables such as the blue and the black make sure the blue is with blue and black is with black. They are hard to see sometimes in a poorly lit area like behind a TV.
If everything is hooked up correctly.
Your next bet is the lamp replacement. Replacing the lamp its quite easy to do. Just remember to reset the TV lamp timer. Consulting your owners manual should help.
Here is the site for lamp replacements. You also can do your own search for lamp replacement.
http://www.purelandsupply.com/GeneralSearch.aspx?search=Samsung%20HLN617W
Posted on Jul 13, 2009
SOURCE: RCA D52W23 HDTV; WHEN WE TURN T.V. ON THE GREEN
most likely its the smsp /deflection board for the shut down
there are some caps in the power supply cp 140 cp120 cp114 look at them and see if there puffed up
they will need to be replaced
this could also be a flyback transformer that has failed or a ribbon connector
this where you will have to look for caps first the trouble shoot through it
then you you can addresse the cmp1 issue but id guess thats the ribbon connector causing that one
Posted on Nov 11, 2009
SOURCE: R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Posted on Jan 08, 2010
