How do I program this scanner
Http://www.uniden.com/cb-radios/bearcat-pro-series-40-channel-cb-radio-with-weather-alert/invt/pc78ltwg
you download the user manual and read it a few times
and play out a few senarios ....
happy days
SOURCE: Uniden Bearcat 210 XLT Base Scanner
Here's another link that will take you right to the manual. Hope it helps
SOURCE: Uniden BC350C Scanner
Start by pressing 'band' & select the band that the freq you want to program is within by using the 'up' or 'down' button, then press 'search' , when you see the display getting close to the desired freq, press 'hold' & then use the 'up' & 'down' buttons to zero in on it. Then press 'program', then press 'private' & select the channel you wish to put it on (1-50). Repeat this process as needed. I find it's easier & faster to program all the freqs within a band as you can assign them to whatever channel you wish within the 50 in the private bank, then do the other bands. Hope this clarifies it, good luck. Regards from Community Communications in Wanaque, NJ.
SOURCE: how to program my uniden bearcat scanner bc350c
to listen to the programed channels you need to turn the squelch up to to the right and press scan it will scan all the channels and stop on the ones that people are talking on. you can down load the user manual at the bearcat scanner website.
SOURCE: i cant get my uniden bearcat 16 channel scanner to
You may not have the right frequencies programmed into the scanner. For an extensive database of frequencies and systems in your area, visit
www.RadioReference.com
or
www.CityFreq.com
SOURCE: I need an OWNERS INSTRUCTION MANUAL FOR UNIDEN BC144XL SCANNER
You can download the complete instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Hope this solves your problem. Thanks for using FixYa.
