Question about Sony KDS-R60XBR1 60" Projection HDTV
<!-- from fixya rte -->How to ck xl5100 bulb on kdsr60xlb1 sony tv? - Sony KDS-R60XBR1 60" Projection HDTV
Xl5100 replacement lamp
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
May 15, 2014 | Sony Office Equipment & Supplies
I bought a new Sony xl5100 lamp. Delicately and accurately replaced the old lamp with the new one. Installed the lamp and housing correctly. Closed the lamp access doors correctly. Turned on TV...red light...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
Jerry
Lampdeng Limited
Jan 11, 2014 | Sony (XL-2400) Projector Lamp for...
I have a Sony KDS-R50XBR1 I cannot remove the "old" XL5100 to replace it I follow the instructions to lift the ring, put my thumb on the groove and pull out Only it won't I cannot see...
XL5100 has lock lever that holds it intact inside tv, you need to put thumb on groove and press it to release the lock then pull out lamp, below image of lamp shows lock lever that moves upward when you press groove so lock gets release and lamp slides out very easily with little pull.
Please check new/ replacement lamp (if it is Sony original, it would be complete lamp including casing) for below mentioned lock function to have better idea how it works.
Hope these info will help you.
Thanks.
Jan 22, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
My Sony KP-51WS510 is out of color focus. The blues and yellows are separating. I know there are three color bulbs that work together to create all the colors. Could the bulbs be out of alignment from...
Convergence ICs and CK all Pico Fuses around ICs they will look like resistors but will be Green or Yellow 5amp, 6amp, 7amp Fuses. Big Black ICs they will have the PN# on them
ICs STK392-110 use 120s Mats 1-800-628-1118
TV Repair Shop $255.00
Oct 21, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony wegas kdsr50xbr1 wont turn on blinking 4 times whats wrong
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL5100 you can find it here: http://www.discount-merchant.com/Sony-Grand-Wega-XL-5100U-Lamp-p/sony_xl-5100u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 12, 2010 | Sony KDS-R50XBR1 50" HDTV
Hi..even though just replaced the lamp XL5100 the blacks still look too blue...is there something else thats causing this??
So you have a Sony TV maybe hopefully not but sony has had alot of problems with the light Engines
high failure rate on them! Just wanted to warn you ahead of time .
Dec 08, 2009 | Televison & Video
Sony KDS-R50XBR1 tv.When press on butten,green LED comes on.TV is on for half second and goes off. The lamp led light blinks red four times and cotinue blinking red.
Hi,it sounds like your lamp needs to be replaced this will be the part you need XL5100 found Original Philips lamp here: http://www.discount-merchant.com/SearchResults.asp?Search=XL5100+ God bless you!
Oct 01, 2009 | Televison & Video
Just replaced the bulb. the tv works fine for 5
Ck Fan to Lamp it maybe Defective if fan stops running then lamp shuts off this is to protect Lamp from getting to hot Call Mats for Parts if it is the fan and Ballast Board is what turns Lamp on. 1-800-628-1118 they sell all supplys for TVs
Sep 26, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
