Here is what I have done in attempts to solve the problem: (1)..Checked the filter..Wasn't dirty. (2)..Tipped unit to drain the water...two drops came out. (3)..Tried resetting it with reset button...Didn't help. (3)..Went through all modes (cool, dehumidify, fan)..seems to cool on dehumidify but not cooling mode, as it was before. (4)..Checked Troubleshooting guide that came with the unit...Did all suggested, but none worked. I bought the unit at an end of season sale last year, but didn't install and begin using until 2 months ago. I'm sure it's out of warranty by now. Any suggestions?
SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
SOURCE: Excessive water draining from portable A/C
It appears that you have changed the location of the unit, I mean have you relocated to an area whwre the humidity is high, usuallly coastal areas have high humidity.If not is there a door that is being constantly left open causing a lot of fresh high humidity air into the room
SOURCE: Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
