Question about Sanyo DP42848 LCD TV
How do I get the DP42848 to accept the HDMI inputs?
Posted by Rusty Holland on
    Top Expert:
  • Sanyo Master
  • 76,416 Answers
You have to connect the TV to any device; which have HDMI output; using an HDMI cable in between, and to select the input of the TV to HDMI, using its remote control's input selector button.
How do I get the DP42848 to accept the HDMI inputs - b22499a3-1216-410c-b219-dff12612f909.jpg
The HDMI cable will look like this.
Posted on Sep 25, 2014
Testimonial: "I did all that. When I select the input on the remote, the TV does not accept it. I used video cables and selected video 1 and got a picture."
Which HDMI Dongle is compatible with Sony Bravia KLV-32NX500 to make it a smart TV ? Please suggest.
As the HDMI input of TVs are only meant to accept video signals (to set HDMI specifications), any SMART TV dongle that attaches to the HDMI port is going to output a video signal compatible with the set HDMI specification. A modern TV like yours will be able to accept the digital video signal from any dongle, as it accepts all the common modern formats (1080p, 1080i, 720p, 576p, 576i, 480p, 480i)
Ref
https://www.engadget.com/products/sony/bravia/klv-32nx500/specs
Dec 23, 2017 | Sony Televison & Video
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Samsung hdmi problems
There should a button on the monitor to switch the input. Press it until you see HDMI on your screen.
Jul 31, 2014 | Samsung T220HD LCD Monitor
Video inputs not working
Which video inputs in particular - all of them or only the HDMI for example?
Consider sending the main board to us for inspection and possible repair:
http://www.coppelltvrepair.com/newservice
It's free if there is a problem and we can't fix it, it's $20 if we test the board and it all seems fine and it's going to be around $70 if we find and fix the problem; return shipping will be about $10, i.e. all before mentioned prices will have $10 surcharge for the return shipping.
(of course prices are subject to change in time, so you may want to contact us first to confirm)
Hope this helps!
Aug 25, 2013 | Sanyo DP42848 LCD TV
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
I do not know how to work the display resolution
The tv display resolution will automatically change depends on your source/device output resolution and TV inputs used as well. Television component and HDMI inputs accept 480i up to 1080p signal while composite and s-video accepts 480i(lowest resolution) signals only. You will get high resolution signals from cablebox, game consoles, bluray etc through their component or HDMI output jacks.
Dec 25, 2009 | Sanyo DP50747 50 in. Plasma TV
Can i use tv as computer screen
The same VGA cable you would use to connect it to a computer monitor.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 29, 2009 | Sanyo DP42848 LCD TV
Sanyo DP42848 LCD TV Logo
97 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
