Question about Mitsubishi VS-50111 50" Rear Projection Television
On my vs 50111 my power button stopped working about 6 weeks ago but i used the remote however now i plu it in and the reen light comes on indicating power but then shuts off right after. it seemed to
Tried unpluin and replugin tried to et an error code dionostic with no luck checked power chord & connectin plug at the end where it actually connects to the set seemed rather loose not sure whats what
Syd Bell
    New Friend:
  • 115 Answers
It could be a simple loose or broken wire,so
take back off and check it.Make sure unplugged first.
Could also be plug end.I have this with our Samsung,
but push the remote two to three times and it stays on.
LUCK
Posted on Sep 25, 2014
5 Related Answers
Lashawn Robinson
  • 1153 Answers
SOURCE: TV turns off right away relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Posted on Aug 27, 2007
Anonymous
SOURCE: Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is [email protected]
Posted on Oct 09, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: WD 52525
This is a sign of a failing capacitor set on the power board. there may have been a small or minimal pulse that went threw the set during the power outage and when the power was restored. this could also be overheating as well due to dust forming on the power boards components. i would remove the back cover and clean as much dust off the power board as possible with some sort of canned air if possible. make sure the cooling system is working properly as well.
please rate and god bless.
Posted on Mar 16, 2009
TexasJohn
  • 12 Answers
SOURCE: My Mitsubishi WS-65511 won't turn on.
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Posted on Apr 15, 2009
Steve Yocum
  • 668 Answers
SOURCE: I own a Mitsubishi HD 1080 series HD TV;
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Posted on Oct 22, 2009
Testimonial: "Thank you very much for the advice. I agree it may more cost effective to "bite the bullet" and buy a new TV."
Where can I purchase a plug in outlet chord (power chord) for the osim medic 380 massage chair
If you are looking for the male end that plugs into the wall, you can use any 3 prong plug made for 120VAc. Just cut off the old one and connect wires to the new one. Black wire to brass terminal (if not brass or color coded, the smaller blade), white wire to silver terminal (no coding, larger blade) Green wire to green ground terminal. Secure in plug and you're goo to go. If you need to replace the plug on the unit itself if it has one or if its hard wired (usually is) you may need to disassemble that part to replace or reattach the cord.
Jan 23, 2015 | Furniture
0xc19a0002
1. connect the printer directly to the walloutlet...
2. then remove the ink cartridges and then clean the copper contacts with a lint free cloth... then put back the ink cartridges... and check
3. then unplug the power chord from the back of the printer without turning off the printer and then press and hold the power button for 30 sec... then plug in the power chord at the back of the printer.. and check if that works...
4. if it does not work then unplug the power chord from the back of the printer... press and hold down the pound(#) and 6 key together... then plug in the power chord at the back of the printer... release the # and 6 key when the printer is powering back on... this is a reset which we are doing on the printer...
if the printer is on check if the error msg is there or not...
if it helps well and good.. however if it does not then try with a different set of ink cartridges... after changing the ink cartridges still it does not work then it might be an issue with the printer hardware...
Oct 17, 2013 | HP Photosmart C6180 All-In-One InkJet...
My Siemens dishwasher of 2.5 yo has shown error code e07. What does it mean? thanks
Most often these are power failure codes. Unplug and wait 230 minutes to clear the board of power. Replugin and try again. This resets the board like rebooting you computer.
Oct 17, 2013 | Dishwashers
Hp officejet 6310 makes loud grinding noise on right side
1) connect the printer directly to wall
2) try different wall outlets
3) unplug the power chord and then press and hold down the power button for 30 sec. release the button.. then plug in the power chord
4) then try to move the carriage manually from left to right.
5) check if any papers or any thing is stuck inside the printer or not..
6) then unplug the power chord.. press and hold the pound(#) and no 6 key together and then without releasing the button plug in the power chord..once the power button in plugged in release the button..
the printer would go back to factory defaults..
check what happens
7) issue not resolved the service the product..
Mar 26, 2011 | Office Equipment & Supplies
Error code 0xc18a0506
1) connect the printer directly to wall..
2) try different walloutlets
3) then do a power drain
unplug the power chord from the back of the printer >> then press and hold down the power button for 30 secs >> release the button >> plug in the power chord..
4) clean the copper contacts and the printheads..
5) replace the printheads
6) service the product
Mar 26, 2011 | HP Photosmart C5180 All-In-One InkJet...
Power chord won't charge laptop
If you need to wiggle the cord in order for it to charge, then you have a problem.
If you have to wiggle it at the computer, you probably have either a bad plug on the adapter or the power connector on the motherboard is going bad. This situation will not cure itself. It will only get worse.
Check the voltage at the end of the power adapter cord (the plug where it goes into the computer). If it's constant even when you wiggle the plug, you're gonna be looking for a new motherboard soon. I have actually replaced the power adapter on motherboards, but it's tricky--you have to be really good with a soldering iron!
Mar 22, 2009 | Dell Inspiron 1525 Notebook
Fax problem
first try to make a copy and check if you get the same error message..
if you get the same error message..try these steps..
1)connect the printer directly to the wall outlet..and try to make a copy..if you get the same error message..then go the next step
2)unplug the power chord from the back of the printer..press and hold OK and CANCEL buttons together..
3)while pressing these two buttons plug in the power chord to the back of the printer..after you plug in the power chord do not release the buttons untill the screen goes blank..
4)once the screen is blank release the buttons and turn ON the printer..
5)wait for the printer to complete the initialization..
6)then try to make a copy and check if it is copying successfully..
if not machine should be replaced because scanner bulb is not getting enough power or scanner bulb is gone bad..
please try these steps and let me if the solution has worked
Mar 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Reset power when it 's plug in
as you are getting the error RESET POWER..
turn off the printer..unplug the power chord..connect the printer directly to the wall outlet..and then turn on the printer..if you are still getting the same error message..perform these steps..
1)unplug the power chord from the back of the printer..
2)press and hold the ON button..while pressing the ON button plug in the power chord to the back of the printer..
3)after you plug in the power chord do not release the ON button for 30seconds..
4)after 30seconds if the printer is off, go ahead and turn on the printer..
the solution should resolve the issue..if its still the same please get back would give you some more steps..
Mar 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer cartridge cradle cannot move
check if you are getting an error message as carriage jam..if you get this message connect the printer directly to the wall outlet and then check for the error message..if it still the same..perform a reset on the machine..that is you need to unplug the power chord from the back of the printer, press and hold OK and CANCEL button together while pressing these two button plug in the Power chord to the back of the printer..after you plug in the power chord do not release those two buttons, keep pressing those two buttons untill the screen is blank..once the screen is blank release the buttons and then turn on the printer..check for the message..if you are still getting any error message then it is a hardware issue..machine should be replaced..
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Sony Handycam Digital 8: won't accept tape
I was having the exact same problem with my sony handycam. I actually came across this website looking for the answer and noticed many people having the same problem but there was no solution to it.
I just happened to go to the sony website and decided to watch the tutorial on setting the camera back to the factory settings. It actually fixed the problem! I don't know if this will work for everyone or even how long it will work, but I figured it was worth a try. Good luck!
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Mitsubishi VS-50111 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
